Junior Russell Posted June 5, 2013 Report Posted June 5, 2013 ok so heres whats up last month i was running my mom around and it started running really rough like more than it usually did about 20 mins later it died and when i started it after letting it cool down it was knocking badly and didnt want to stay running since then it has knocked heavily and hasnt wanted to run for more than 15-20 mins without dying since then i have stripped all my audio stuff andreturned it all to stock trying to sell and replace it but to no avail yesterday i started tearing it apart to find the problem and nothing yet heres what ive taken off and inspected: alternator and bracket-really dirty but nothing wrong with it distributor-worn distributor gear but otherwise ok intake manifold (lower and upper) and throttle body- tb is ok upper intake is dirty but ok lower intake is really dirty but otherwise ok valve covers- dirty outside, clean inside driver side rocker arms and push rods- good as far as i could tell (rods looked straight and rocker arms looked fine (no un natural bends or knicks or anything)) drivers side head (wasnt able to get it off(all unbolted but wouldnt come off))-filthy passenger head still bolted on- dirty but not as bad as the drivers side wouldve kept working but it was about to start raining so i had to stop put the hood back on and put everything up for the day im a decent mechanic learned almost everything i know from my dad but im stuck. anyone else have this problem and know whats wrong or have any suggestions all help would be greatly appreciated thanks in advance drivers side passenger side drivers side rocker arms rods bolts and cover distributor gear intake manifold injectors these two (for cylinder 3 and 5 are really dirty) http://www.youtube.c...e1?feature=mheehttp://www.stevemead...87#entry1993187 JVC KD-R530 head unit VVME INNO-D1500 sub amp Kenwood KAC-8402 amplifierPioneer 2-way 6.5 X2 @ 4 ohms DTI Audio 6.5 X2 @ 4 ohmsbox: 4.24 ft^3 tuned to 61 hertz (port walls fell off and dissapeared )
jagblazer01 Posted June 5, 2013 Report Posted June 5, 2013 try dropping the oil pan and checking the pump. You may of had the oil pump fail and something in the bottom end got messed up Team Sundown Audio / Team XS Power / Team SHOK SMD Super Buyer/Sellerwww.sundownaudio.com www.shokindustries.com www.4xspower.com www.excessiveamperage.com
ToNasty Posted June 5, 2013 Report Posted June 5, 2013 head gasket i bet, i have had 8 s10s same motor and i had the same thng happen ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
tacomaguy1 Posted June 5, 2013 Report Posted June 5, 2013 what did the oil pressure gauge show Team Flex Issues
tacomaguy1 Posted June 5, 2013 Report Posted June 5, 2013 http://blazerforum.com/forum/2nd-gen-s-series-1995-2005-tech-41/help-my-balzer-trashed-77945/ Team Flex Issues
ToNasty Posted June 5, 2013 Report Posted June 5, 2013 also do like said, drop the pan and the pick up could be clogged from the head gasket going out ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
Junior Russell Posted June 5, 2013 Author Report Posted June 5, 2013 oil when started and driving usually around 40+ idle about 31 and intermittently (bout once or twice every 50+ miles) drops to 0 with check gauges light never lasts more than 1-2 seconds and as stated in op i cant get the head to come off to check head gasket, everything is unbolted from the head but it wont budge will do as suggested and drop the pan in a bit thanks all will report back also how do you tell if the oil pump is bad? edit~ also ive checked blazer forum only thing i found on there was to check the lifters, rods, rocker arms and valves http://www.youtube.c...e1?feature=mheehttp://www.stevemead...87#entry1993187 JVC KD-R530 head unit VVME INNO-D1500 sub amp Kenwood KAC-8402 amplifierPioneer 2-way 6.5 X2 @ 4 ohms DTI Audio 6.5 X2 @ 4 ohmsbox: 4.24 ft^3 tuned to 61 hertz (port walls fell off and dissapeared )
jagblazer01 Posted June 5, 2013 Report Posted June 5, 2013 Get the heads completely unbolts and take a rubber mallet to them. They should pop right off. Team Sundown Audio / Team XS Power / Team SHOK SMD Super Buyer/Sellerwww.sundownaudio.com www.shokindustries.com www.4xspower.com www.excessiveamperage.com
Junior Russell Posted June 5, 2013 Author Report Posted June 5, 2013 ah ok thanks dude http://www.youtube.c...e1?feature=mheehttp://www.stevemead...87#entry1993187 JVC KD-R530 head unit VVME INNO-D1500 sub amp Kenwood KAC-8402 amplifierPioneer 2-way 6.5 X2 @ 4 ohms DTI Audio 6.5 X2 @ 4 ohmsbox: 4.24 ft^3 tuned to 61 hertz (port walls fell off and dissapeared )
