Need Advice re: Torres Calculator results
its 5.5-7cuft per chamber (box for 2 subs). i would do the design in #1 so that the ports will be at the top of the car along the roof but i would drop the volume down to 7cuft and that will help make it easier to get the port volume up to 14-15" per cuft.
or if you want to do option #2 i would stack on box on top the other so that the port would be going up and down in the middle of the car. once again though get the volume down closer to 7cuft and that will help make it easier to get to the 14-15" per cuft
Got it sir... Hope you can checkout my new design
If you have 2 chambers then each chamber need to be 5.5-7cuft.
5.5-7cuft per sub or per enclosure? ( 1 enclosure holds 2 subs) i'm leaning towards design 2 ( 2 subs port in between the subs) what can you say about the results in torres that i made?
Might not be able to make design 2 sit on top of the other coz the width is 40" and my trunk's width is only 38" max. I'll try to fix the design 1 and try to drop it close to 7cuft and adjust port area close to 15" per cuft. Do i need a powerful amp to make a 7cuft loud compared to 8cuft? I asked because at present i only have a single 1500.1 driving all 4 subs but i have plans of adding another 1500.1 in the future
if you plan on over powering them then it being smaller will help with the mechanical limits of the sub. i mean you could build a big box for while you run just a single 1500.1 but once you get a second 1500.1 you will be overpower the subs a bit so you should consider building a smaller box at that point. or you can just do a smaller box now and not build another when you get the second 1500.1.
in other words yes to get more output from a smaller box you will need more power but if you dont want to build a wall tear it down and then rebuild it agian when you get a second amp then just build it once. then when you get the second amp your ready to go.
its all trail and error, no one can say for sure if those subs will like 4cuft each or 3cuft each. no one can say if they will like the extra power in a bigger box or a smaller box. the most some one can say is what they would.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
not sure on the 45s ive never had to do it before.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Got it... I might just build it at 3.5 cuft / sub since most of i know how uses it builds it at 3.5 cuft / sub. How do i compute the displacement of the 45's i made? Is there a calculator for it?
The formula to calculate the volume of the prism is 1/2*L*W*H.
Thanks man! Noted.
... well.... I did know that formula... now I just feel stupid...
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 1310 Guests (See full list)
