Box for 3 sundown sa 12s
Here is a suggestion, check the notes below the pic, now you will probably need to wire to 2.6 ohm so you won't be getting near the power these subs can take:
Enclosure Specifications:
Fb = 34 Hz
Vb = 6 ft^3
External Height = 20 in
External Width = 43.25 in
External Depth = 19 in
Port Width = 20 in
Port Height = 3 3/4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 43 1/4 x 19
Left & Right Sides = 17 1/2 x 17 3/4
Front & Back = 43 1/4 x 17 3/4
L Port Internal Assembly Parts:
Front to Back = 13 3/4 x 21 1/2
Extension = 1 1/8 x 21 1/2
Port Left Side Assembly:
13 3/4 x 3 3/4
5 5/8 x 3 3/4
Port Right Side Assembly:
13 3/4 x 3 3/4
5 5/8 x 3 3/4
Assembly guide (generic dimensions):
Important notes:
- All boxes built outside the vehicle need to fit in their way in not just have the right dimensions.
- The port needs 3 3/4" of free airspace in front of it for proper operation.
- Setting your amp subsonic filter to 28Hz is suggested.
I was actually planning on wiring it down to .66 (don't know why i put .75 at first) ohms because my amp is stable to .5 ohms I have a 160 amp alt and group 94 batt up front and a group 34 agm batt in the rear. Would this box still work for if the power is increase to the subs. By the way thank for the detailed reply I plan on starting on the box tomorrow.
I was actually planning on wiring it down to .75 ohms because my amp is stable to .5 ohms I have a 160 amp alt and group 94 batt up front and a group 34 agm batt in the rear. Would this box still work for if the power is increase to the subs. By the way thank for the detailed reply I plan on starting on the box tomorrow.
Yes it will work, as before read the notes below the pic.
  • 4 years later...
Fb = 34 Hz
Vb = 6 ft^3
Port Width = 20 in
Cut Sheet List:
13 3/4 x 3 3/4
5 5/8 x 3 3/4
13 3/4 x 3 3/4
5 5/8 x 3 3/4
Important notes:
  • Who's Online   0 Members, 0 Anonymous, 1186 Guests (See full list)
