Help designing and tuning box for Yukon
Here is a suggestion, slot port though:
Enclosure Specifications:
Fb = 36 Hz
Vb = 5 ft^3
External Height = 18.5 in
External Width = 39 in
External Depth = 20 in
Port Width = 4 3/4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 39 x 20
Left & Right Sides = 18 1/2 x 16 1/4
2x Front = 17 1/8 x 16 1/4
Back = 39 x 16 1/4
Shared Port Internal Assembly Parts:
2 x Front to Back = 16 1/8 x 16 1/4
2 x Extension = 1 9/16 x 16 1/4
Assembly guide (generic dimensions):
Important notes:
- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port here's how you do them:
- All boxes built outside the vehicle need to fit in their way in not just have the right dimensions.
- This box should be operated around subwoofer(s) rated power. If that´s not the case, let me know.
- The port needs 4 3/4" of free airspace in front of it for proper operation.
- Setting your amp subsonic filter to 28Hz is suggested.
Here's one with a round port (not showing bracing) the problem is the squarish form factor if you do mind that:
Fb = 36 Hz
Vb = 5 ft^3
External Height = 18 in
External Width = 30 in
External Depth = 24 in
Cut Sheet List:
2 x Top & Bottom (3 parts) = 30 x 24
Left & Right Sides = 22 1/2 x 15 3/4
Front & Back = 30 x 15 3/4
Port Quantity and Dimensions:
Number of Ports = 1
Pipe Port Diameter = 8
Pipe Port Length = 14 3/4
Assembly guide:
2x12hdc3_zpsc5e36bd1.jpg}
- The port needs 8" of free airspace in front of it for proper operation.
remember his cargo area is 49" wide
REP
i would do subs and port back. your truck peaks at 38-39hz so i would tune at that or just under.
REP
  • Who's Online   0 Members, 0 Anonymous, 931 Guests (See full list)
