Unless maybe when u rev something big electrical is turning on and pulling more power causing it to drop lower?
Edit: Like compressor not workign then revving up makes compressor clutch catch and drag it down? idk just shooting out stuff
I put a new belt on, the belt only runs the alternator and water pump. Its a small vehicle, no AC or PS, very straight forward. I measure the voltage on the battery terminals and from alternator B+ to batt neg and chassis and the reading is the same, checked all grounds as well.
Where are you measuring voltage?
sounds like the voltage regulator is shot, might need a new alternator
25d9cf71-fff8-4b67-a8f5-28c80d5ea859_zps7d3fe7f6-90c4-4939-b709-43f0e5812212_zps
2018 Honda Civic Sport Hatchback (build in progress)
NVX Sound Deadener (Front Doors)
Stinger FAST Rings
Stock Electrical
SSA Evil 6.5's Front Speakers
Stock rear speakers
MB Quart ONX4.80 speaker amp
Rockford Fosgate T-1500bdcp
DC Level 4 12" D1 @ 2-ohm
Box In Design Stage
Stock Radio
My Build Log
I found a blog forum on the issue, said the following :
What do you guys think?
Voltage Regulator
  • Nearly every automobile alternator-generator unit is coupled with a voltage regulator, which determines the actual output of the alternator. The voltage regulator detects the charge level of the battery and can decrease the voltage output of the alternator once the battery is nearing full capacity. As a result, the voltage output from the alternator, as it produces electricity for the vehicle's battery, may drop once it has reached higher RPMs if the electrical load requirement is low.
Read more: Why Does an Alternator Drop Voltage When Sped Up? | eHow http://www.ehow.com/info_7791228_alternator-drop-voltage-sped-up.html#ixzz2W11n1YWx
  • Who's Online   0 Members, 0 Anonymous, 1598 Guests (See full list)
