1999 Chevrolet Blazer - Stereo Integrity, Ground Zero, Soundstream
Been going pretty slow, been doing alot on the new bike lately. Here's all I have done:
346E6A91-25E9-4EAE-8A8E-AC1DB011420E_zps
Need to order the paint for the port to match the basket and figure out the best way to put this together.
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
F902E889-6B77-4966-A9DF-2AF8415B65FE_zps
Already messed up. Put the upper side panel on before I put the port section in, so I can't screw the side of the port into the upper port section. Shouldn't be a huge deal, I'll just shove some wood in there while the glue dries so it's tight.
Ordered the paint for the port and inside the box, and ordered some white LEDs as well for inside the box. Turns out the basket paint probably doesn't glow under UV, so going with white instead.
Remember when I said it would barely fit? Well, I wasn't joking:
0F5CCCE6-63F6-4BF7-8CF6-86A2F5667517_zps
1FF01B12-B103-4F59-A62E-514B363AFE8B_zps
This port is freakin' huge. Glued the inside pieces together and dropped them in, but I will be taking them out to throw some bondo in the port corners.
AE90740B-7124-4D62-840F-B56DA9A163C3_zps
Dry fit with the back:
C2052A81-41FB-4849-9DC2-498BB314F89B_zps
Got the back glued on:
8016550A-67E0-4B51-8592-F5C7E33332B8_zps
Took the port back out to do the roundover on the port edges, both inside and outside:
38B0C95D-F2E3-4AAF-9E21-4AC97EBFF8B1_zps
Can't do 45's, so I'm just putting a block in to fill space. I will be doing a smooth round corner with Bondo.
588EFAC4-BAD5-47AE-9ED0-A33F6C1F9CAF_zps
I envy you guys that have shops or even garages. Doing all this in my spare room lol.
E8CEC57B-90C4-439E-BF19-506965BDFF5D_zps
First coat of Bondo:
198D92F9-6DB2-4121-921B-1ABCC8818324_zps
Second coat:
C2D60B10-24F9-4FFA-B55E-8B8233E21EB1_zps
Not gonna worry about getting the curve perfect, just want it smooth. This is almost a gallon of Bondo already lol.
Also picked up some 1.25" dowels. Should keep it fairly stiff.
691884DD-9400-416C-ACEE-BD12E85004DD_zps
Shaping up nicely. :)
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
shiny and clean ;-)
06 Trailblazer ss
2 Team shok industries tsx 18s
Phoenix Gold ''THE ONE''
2 Phoenix gold 800.4
4 crescendo mp6.
2 crescendo mp8
bass processor
Dc power 270xp
150ft 1/0 ofc sky high cable
1 juicebox lithium 0.5kwh 14v/40ah
kenwood dnx8120
BCAE1.com
YouTube channel : REaudioxxx1
build log: http://www.stevemeadedesigns.com/board/topic/160106-trailblazer-ss-xxx/
Got a bunch done tonight.
Did some sanding. I HATE sanding.
48700614-5419-4ED1-99BE-EFCF65B430EE_zps
Shot it with primer to see what it will look like. I'm saying F it, I'm leaving it like this, I don't even care. I HATE sanding!
58FCE872-E697-4B0F-A30B-BCB66D436204_zps
1.25" dowels for support:
BFFF45FA-1984-490E-B69E-519028C86663_zps
Put the plexi mounting ring in:
0982D6CE-F0C4-4C62-8788-2E1420DE2CD3_zps
C87D805B-58C9-44D3-A501-886991F3FC36_zps
Put the port back in just to fit for the top pieces.
191101DC-9FDB-48DE-B005-9475B31D906E_zps
First baffle:
29F4F060-A951-4454-9871-6F65DE0F6BB8_zps
Second baffle:
44973CA1-B9B1-4D7B-8298-DB5EAB895C2A_zps
Still got a bunch left to do actually. Turning out to be more work than I expected in order to finish it the way I want. Oh well, should turn out good, and it's not like I've got the SHD yet.
Also got the paint. Green for the port, white for the inside:
6F4132C3-AC6F-47EC-A501-907CDE958DA9_zps
And the lights for the inside as well. Yep, they're vehicle fog lights lol. I figured they'd be strong enough to hold up for a little while.
8D811F9B-DE22-4F72-BB35-F52630339F85_zps
  • Who's Online   0 Members, 0 Anonymous, 3448 Guests (See full list)
