MACnonsence6 Posted June 20, 2013 Report Share Posted June 20, 2013 if someone did something silly like idk jb welded a basket to a motor what would be the proper way to remove it I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha. Link to comment Share on other sites More sharing options...
revoracing247 Posted June 20, 2013 Report Share Posted June 20, 2013 grinder? lol and a bit of luck I think you have a bit of truck stuck in your mud bro ~Ford Ranger, ext cabKenwood DDX4701/0ga stinger wiring for big 31/0ga ofc flextech wiring 3 kinetik 800's AQ2200 @1ohm Sundown Audio X15 in a 27Hz tuned ported box LE BUILD LOG!!! Link to comment Share on other sites More sharing options...
Krakin Posted June 20, 2013 Report Share Posted June 20, 2013 Found this. Q: How can I remove J-B Weld after it is fully cured? A: When fully cured, J-B Weld can only be removed by grinding or filing it off, or by directly heating the product above the 600º maximum temperature threshold. Sorry man haha edit: from http://www.jbweld.com/faqs/ Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener. Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted June 20, 2013 Report Share Posted June 20, 2013 i would not heat a motor to 600 degrees..... just saying. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
jbarnes3123 Posted June 20, 2013 Report Share Posted June 20, 2013 Looks like someone made a life decision. 2006 Kia Spectra5 http://www.stevemeadedesigns.com/board/garage/vehicle/2398-kia-spectra5-2006-spectra5/ (garage) http://www.stevemeadedesigns.com/board/topic/169164-06-kia-spectra5-hatchback-previous-work-current/#entry2474426 (builds) Link to comment Share on other sites More sharing options...
MACnonsence6 Posted June 20, 2013 Author Report Share Posted June 20, 2013 its jb quick. i did the same thing to the other sub that i built and just the normal use of it broke the jb weld. not sure how hot the motor got with normal use but hot enough to get the jb quick to loose its grip I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha. Link to comment Share on other sites More sharing options...
dfoland93 Posted June 20, 2013 Report Share Posted June 20, 2013 The spot with least resistance LOL. I would ground to a rubber dildo if it had less resistance than a run of 4/0 wiring. how many poeple work there 3 or 4 lol At crescendo HQ? probably 2-3 At the sweatshop in china? 30,000 children No Engine Link to comment Share on other sites More sharing options...
MACnonsence6 Posted June 22, 2013 Author Report Share Posted June 22, 2013 took all the bolts out held the motor and tapped the basket on a table and it popped right off I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha. Link to comment Share on other sites More sharing options...
Bship Posted June 22, 2013 Report Share Posted June 22, 2013 I loled a lot, thanks for the laugh. glad It turned out well CARS 14 Sierra crew cab daily, Small build coming one of these days 69 C-10 fleetside in many pieces, won't be done till the end of time Last car '12 Focus with build log http://www.stevemeadedesigns.com/board/topic/165619-2012-focus-btl-15-crescendo-sundown-audio-control/ Link to comment Share on other sites More sharing options...
