help bridging my 4 channel
DylanBunch
So I had to send one of my ft1s back to crescendo cause it blew and for the time being I only have one. Is there a way I can wire just the one tweeter to channels 1 & 2? Cause I have my 4 mids in channels 3 & 4
2006 Ford Explorer
2 Team AA/Sundown 15s
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
you can bridge it but why not just run it one ch 1
Used to have a loud truck
Well if its bridged it'll be at a lower ohm load I assume, and the higher power will make up for having 1 instead of 2
2006 Ford Explorer
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
and you will pop the other one from trying to run too much power through it, what amp and what ohm tweeter?
The tweet is 8 ohms on a kicker 350.4 60 x 4 @ 4ohms
2006 Ford Explorer
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
you could get away with it since that amp probably puts out around 60rms bridged at 8ohm but if it was me I'd still just run it off one channel
Well, how bout this. Tell me what to do to bridge it and ill see if the difference is big or not and if its not ill just run it off 1 channel
2006 Ford Explorer
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
Put positive from tweet on channel 1 and negative on channel 2 is what it should be. And if Im not mistaken it also shows you on your amp how to wire it Bridged. It should be right in the middle of the amp on the right side...
  • Who's Online   0 Members, 0 Anonymous, 398 Guests (See full list)
