Battery Drops While Waiting for Light at Night
Hey guyz, im having this issue with my battery, should i be concerned? my problem is my battery meter drops down to almost the red zone (car stock meter) when I'm idling and have my music bumping at a light or a fast food drive-threw. during this time the meter starts to slowly drop. This is worse at night with my HID's on and the brake light on as we'll. I installed everything my self, i got a XS Power D3400, Big 3 (0 gauge), Alpine PDX-M12 AMP, (2) 12W6v2 and an upgraded 220amp Alternator. is this normal to happen while idling? is my alternator not big enough? or is there something i did wrong?
thankz for the response and the time.
Sounds like your alternator isn't spinning fast enough to fully field when at idle. Smaller pulley should fix it.
TEAM SOUTH Bassahaulic Productions
The ONLY Bright Atlantic Blue DiamondBoxx L
Drew Jones
4 SSA ZCON 15"s
2 Sundown SCV-6000's
6 AGM G31's
161.6 @ 40Hz Outlaw
159.8 @ 36Hz Legal
┌∩┐(◣_◢)┌∩┐
Also what are the resting voltages and the voltage it drops down ti
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
where did you get the 220 amp alt from?
took my stock alt to a auto part shop & repair and had the guy rebuild it up to 220amp
you likely have jack shit for idle output then. you CAN get a smaller pulley to remedy the low output issue, but i'd be wary if the internals can handle the extra rpms from the smaller pulley.
my resting voltage is 12.8v, the voltage at first time start and idle is 14.5, and the lowest it drops is 12.5v
by worries of my internals do you mean like the timing, the A/C and the water pump and all that shit?? and what are your thoughts on maybe an adjustable regulator (AVBM 2) and having it cranked up to i dont know maybe 14.8 - 15v??
avbm wont do anything iirc. its only useful if your alt can actually support the current draw from the amps.
  • Who's Online   0 Members, 0 Anonymous, 3368 Guests (See full list)
