Jbiddle530 Posted June 23, 2013 Report Share Posted June 23, 2013 So I am looking into a fi q 15 for my single cab truck system. Problem is I don't have room in the cab so it has to be a blow through. What kind of enclosure would be best in a blow through enclosure. Am i stuck with a 4th or 6th order or is there a way to do a t-line in a blow through?? Or would I be better off with 2 12s in a 4th order design. Link to comment Share on other sites More sharing options...
john253a Posted June 24, 2013 Report Share Posted June 24, 2013 Look in 8" and leave them in the cab DD do an awesome 6.5" and there is also sa8 If you want a blow through 10 or 12 will work 15's you may have to lay the sub down, if not they'll work as well You can do a normal ported box and just make the hole as big as possible Or look at 4,6 and 8th T-lines are nice and will work same as a normal ported box, just cut the hole as big as you can and seal the box to the rear bead and put according rubber between the cab and bed Link to comment Share on other sites More sharing options...
Jbiddle530 Posted June 24, 2013 Author Report Share Posted June 24, 2013 I literally only have 4 in he's behind the seat and the cab and I really like the bench seat that's why I wanna do a blow through but thank you for the input. It's much appreciated Link to comment Share on other sites More sharing options...
jhmeg2 Posted June 24, 2013 Report Share Posted June 24, 2013 hellz yeah. do it. tha will be bad ass. where you at, I will help. ////Alpine, Eclipse, Load Boss, Pheonix Gold, MB Quart,Digital Desings, Memphis, Stinger, Periphial, MTX, Visualogic Link to comment Share on other sites More sharing options...
Omega5002 Posted June 24, 2013 Report Share Posted June 24, 2013 I never seen a t-line blowthrough, would be neat 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick) Link to comment Share on other sites More sharing options...
Jbiddle530 Posted June 24, 2013 Author Report Share Posted June 24, 2013 I live in ukiah California.. And I'm really wantin this t line blow through. Only think I am not sure of yet is if I wanna use a 12 or a 15 because I only have about 16 Inches of total height to with with. Link to comment Share on other sites More sharing options...
BobbyG2 Posted June 24, 2013 Report Share Posted June 24, 2013 Could angle the baffle a little, should fit fine. *New vehicle and system coming soon.* Link to comment Share on other sites More sharing options...
Jbiddle530 Posted June 24, 2013 Author Report Share Posted June 24, 2013 Kinda leanin towards just a single 12. I think it will be enough for what I'm lookin for Link to comment Share on other sites More sharing options...
