Tahoe 2013/2014/2015 RF, FI, XS, SQ, TM, etc...
Here is a break down of my under hood battery wiring. I used a Auto Electric Big 3 kit and installed per the instructions to a "T". Both grounds i tried to show in the video go to the frame and i assure you they are Good grounds. Also, there is one battery to body ground i forgot to add to video. Thanks all for the suggestions and ideas.
What sensor am i suppose to run a ground through? Please be more specific as I have no clue... Thanks guys
http://youtu.be/_v7DOROLSBg
Check out merzbow's build log, it should help you a lot.
http://www.stevemeadedesigns.com/board/topic/119827-2011-chevy-tahoe-10k-watts-4-fi-btl-15s-4-dc-power-alts-ubl-edition/?p=1687327
And read this post also.
http://www.stevemeadedesigns.com/board/topic/129909-pcm-controlled-ho-alt-experience/?p=1829177
Cool man, thanks!! I did already re-run the 1/0 aftermarket ground through the sensor but it seems like i should also take out the factory ground that is still in going to the engine? Thus having only 1 wire from battery to alt as positive and it being 1/0 gauge. Then having engine ground removed and aftermarket 1/0 gauge from batt straight to alt and running through that sensor? How does that sound? correct?
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
hey man, did you ever get my video of my t2?
Um, did you PM it? I don't think i did, please send it again?
2006 Ford Explorer
2 Team AA/Sundown 15s
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
Damn man, thanks for posting! Great video, i can't wait!!!!!!
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
Yes, sounds like you got it right, but leave the small headlight return wire in and keep it running through the current sensor with your new 1/0 gauge.
As for your positive, you can leave all your stock positives in and just add a 1/0 positive from batt to alt.
no problem man! even tuned at 28ish it still plays highs pretty damn well. Don't be afraid to tune mid to low 30s
2006 Ford Explorer
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
That T2 was getting down in that video. Nice woofer porn.
thanks bro! Its weird cause in person, it seems like the lowest note in that song is the loudest but its opposite on camera O.o
2006 Ford Explorer
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
Alright, fixed the wiring issue due to 2005 or newer GM vehicle. Got it right now.
Vehicle off and Vehicle on...
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
