Rockford96 Posted June 25, 2013 Report Posted June 25, 2013 Lol well good thing you figured it out My setup, Digital Designs M80 3 Re audio 10's ported tuned to 36 hz Kenwood x-696 SHCA 0 gauge Polk audio coax running off hu
banginhummer Posted June 25, 2013 Report Posted June 25, 2013 I'll take that kylar96, sense you have no idea what My garage stores. And I posted that just from my experience. Take it or leave it. All electrical guys will say stay away from solder with the big wires. Unless you're using the REALLY expensive pure stuff. *Hummer H3* HeadUnit Pioneer AVH-X4600BT Mids and Highs 8-CT Sounds Pro 8" 8ohm 4-CT Sounds Pro Tweeters Amplifiers 1-CT Sounds 125.4 1-CT Sounds 60.4 1-CT Sounds 7000.1 Electrical 3-Runs of 1/0 CT Sounds 8-XS Power D3100 3-Iraggi 300 amp Alternators Subwoofers 4-SQ Hdc3 15" Subwoofers (Soon to be 4 15" Ct Sounds EXO)
slowfkncar Posted June 25, 2013 Report Posted June 25, 2013 I also have ZERO voltage loss with no music playing. And I go from 13.9 to 13.3 under full load. Audioque 3500.1 dual inputs 400a max,and two zx650.4 160amps max. Check your batteries and make sure ALL of them are functioning perfectly
ncc74656 Posted June 25, 2013 Author Report Posted June 25, 2013 i checked my batteries today, they are good. im replacing my alternator wire now up to 0ga. im grinding new ground connections on the frame, body, and block. im going to run a new common ground from the alternator mount bolts to the neg battery. im going to take my other 2 amps and run there grounds down to the frame (they are body grounds right now) and then we will see where im at. the belt is now back on and the alt is charging again. i still think i need a larger alt tho. nothing, gutted
Nate Futuristic Posted June 25, 2013 Report Posted June 25, 2013 I'll take that kylar96, sense you have no idea what My garage stores. And I posted that just from my experience. Take it or leave it. All electrical guys will say stay away from solder with the big wires. Unless you're using the REALLY expensive pure stuff. wonder if 60/40 rosin is pure enough O_O down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups ^^ Cant wait to swalllow Ghost's babies
