HOW DOES IT WORK!?
Kade
generally you use the OEM trim panel and only glass/bondo the front side, the snaps or shape doesnt change on the backside (mounting side), so it should just fit back in like normal, especially with A-pillars and kickpanels. Doors are a little more tricky since you generally mount it to the inner door skeleton (the metal skin with holes in it) with screws like said above. The first ever set of kicks i did fit in VERY snug and pressure fit in so i didnt need to do anything except tap it into the corner with a rubber mallet.
They go back on with oem mounting?
Didn't realize that would be enough to hold it on considering the extra weight. (If it were super tweets)
people dont generally use full size super tweeters in the A pillars, they use regular soft dome or little neo 3in fullranges or something. people put super tweeters in the doors.
From what I've seen, most of the door panels, kick panels and pillar pods are formed directly to the originals. They aren't a separate piece that attaches to the original. Or they are complete replacements for the original.
By your first sentence, you mean that the glass sticks to the existing panel? Then, you build a shell over that piece?
2009 Dodge Caliber SXT (Silver)
Deck: Pioneer X3600BHS
Amps: RF P1000X5
Front: RF P16-S
Rear: RF P1694
Subs: 1 RF P3D2-10
Cabling: Stinger 6 channel RCA, RF 4gauge kit, SkyHighCarAudio 16gauge speaker wire.
Build Log: http://www.stevemeadedesigns.com/board/topic/188246-caliber-build
Professional Networking: https://www.linkedin.com/in/kade-mallett-332b8a104
yes, you get fleece or some other stretchy fabric and pull it over a form/baffle you attach to the OEM panel, attach it with spray glue, then brush on resin to the material. Let the material harden, then add fiberglass chop mat to the back for strength. then grind down/sand down to smooth edges, and make the contours flat and smooth, then paint/cover in carpet or vinyl.
here is my first set.
not the best kicks ever, but you get the point. base is the original OEM kickpanel
That^^
Several systems, several vehicles. Always changing!
2013 MECA State Champion (trunk 1)
2014 MECA State Champion (mod 4)
2014 MECA state Champion (Park and Pound 4)
2014 DBDRAG 6th place North America Finals (SS1-2)
2014 BASS RACE 6th place North America Finals (139.9)
That clears up so much.
Amps: RF P1000X5
Front: RF P16-S
Rear: RF P1694
Subs: 1 RF P3D2-10
  • 5 weeks later...
So that same basic concept goes along with door panels right?
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
  • Who's Online   0 Members, 0 Anonymous, 1460 Guests (See full list)
