hertz2beloud Posted June 27, 2013 Report Share Posted June 27, 2013 they will be powered by 2 rockford t 1000 bdcp for now. going into a acura integra hatch. measurements are as followed width is 30 inches length is 50 max seeing the backseat is out height is 14 willing to pay for help if needed Link to comment Share on other sites More sharing options...
john253a Posted June 27, 2013 Report Share Posted June 27, 2013 14h x 30w x 50d sub up port foward accross the bottom 114sq" of port 4"h x 28.5"w x 31"long = 6@33 Link to comment Share on other sites More sharing options...
hertz2beloud Posted June 27, 2013 Author Report Share Posted June 27, 2013 can someon give me a cut sheet i tried and think i screwed it all up. also should i have bracing and if so where? should i round the edge of the port piece? ill be ok having all the subs in the same chamber? Link to comment Share on other sites More sharing options...
john253a Posted June 27, 2013 Report Share Posted June 27, 2013 Def need bracing and double baffle top but it doesn't fit in the space you have without tunning it higher or going up to 14.75" Link to comment Share on other sites More sharing options...
hertz2beloud Posted June 28, 2013 Author Report Share Posted June 28, 2013 i left some extra space while doing the measurements. so i think ill be ok on a double baffle. what should i use for bracing any suggestions? Link to comment Share on other sites More sharing options...
Joe X Posted June 28, 2013 Report Share Posted June 28, 2013 Consider a wall as well. Link to comment Share on other sites More sharing options...
john253a Posted June 28, 2013 Report Share Posted June 28, 2013 1/2 all threat or 3/4" dowel Brace the centre between the subs through the port to the base (this will brace port top and bottom) And if you have enough 1 or 2 in each direction Link to comment Share on other sites More sharing options...
hertz2beloud Posted June 28, 2013 Author Report Share Posted June 28, 2013 i actually wanted to do a wall but i am just afraid its beyond me and mt friends expertise. but here is what i have to work with for a wall. where the backseat was i have 20 d x 45 w x 30 h if someone can use these or tell me what else is needed id love to try a wall. Link to comment Share on other sites More sharing options...
Joe X Posted June 29, 2013 Report Share Posted June 29, 2013 The problem with walls are how to bolt and seal off properly, take a look at strangeduck's build on here, he has made a wall on a hatchback 4 12s, it will give you an idea on how to go about it and if it's worth to you the extra work, a wall will definitely take more advantage of your gear. Link to comment Share on other sites More sharing options...
hertz2beloud Posted June 30, 2013 Author Report Share Posted June 30, 2013 we just read the accord build, wow i did not imagine all that was entailed. my buddy seems to think we should take a shot at a simuliar design in the teg. anyone mind working out a design ? port being in the same spot it was in ducks build. i dont need the port removable like his. i have measurements above for what i have to work with Link to comment Share on other sites More sharing options...
