After 25% throttle no more acceleration?
so my gf bought this miata and I finally drove it the other day and I found something really weird
first off its a 91 and has a stupid shift kit on it
that being said 75% of the movement in the gas pedal does nothing, the last 75% to be exact. the first quarter is normal but from a quarter to mashed in the floorboard there is no change at all.
Also, I noticed the car shifts stupid early. Even with your foot hard down it will shift just before 4k and the damn thing redlines at 6.5k
At first I thought the car just had a bitch motor but I honestly think something else is afoot. Any ideas?
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Possible throttle cable is stretched? Have someone hold the pedal on the floor, and physically look at the throttle plate, see how far it's opening. Something that's quick to check, may not be the issue at all, though.
its a miata. and a 91. it may be all its got
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
thats exactly what I thought to begin with but then I drove it. Ill have to look at the throttle cable see if that is all good. maybe I am just used to cars that work better but never have a I drove a car that would not get to its redline and that list of cars includes a 92 buick lesabre
something doesn't seem right about it
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
you might take it to the mazda service center and have it hooked up to the OBD1 scanner. the car might be in limp mode. i believe mazda was still using limp mode until the mid 90's around the time OBD2 was starting to roll out
This page is crispy_chick3n approved.
© crispy_chick3n inc
Some cars have a detent cable, if the bushings are bad in it or it's adjusted wrong then the transmission doesnt know how much throttle the engine is getting so it shift early and won't downshift on hills.
It goes from the throttle to the transmission.
  • Who's Online   1 Member, 0 Anonymous, 1163 Guests (See full list)
