Bad fuel pump? 2003 chevy Tahoe
Hey guys, the family and I went out running errands today and our tahoe ran fine all day, until we were coming home from our last stop. I noticed when I started it, it kinda hesitated and sputtered after it started but then idle normally after a few seconds. Then when we started driving home, the truck started to surge and jerk randomly but would eventually smooth out as long as I would ease into the throttle. The check engine light also came on.
After we got home I shut off the engine and then turned it back on and drive it to a friends house who has a code scanner and it ran fine the whole way to his house. Turns out the codes were "bank 1 running too lean" and "bank 2 running too lean" he cleared the code and I then drove home. It started out running fine until about a mile after I left when it started jerking and surging again. It also died on me twice and one time it took me a few minutes to get it started up again. I was able to limp it home and as long I didn't accelerate too hard it seemed like it would run fine.
So does this seem like a fuel pump or something else? I think it may be the fuel pump but don't want to throw money at that if its something like a leaky intake manifold gasket, or dirty mass air flow sensor. What are your guy's thoughts?
Knowing chevys it definitely sounds like it. To test something, get a hitch or something with a lot of weight to it but you can swing, have someone try to start it while you bang on the gas tank. It could cause the parts inside the pump to unstick and run like normal. Cleaning the MAF on those are really easy too. Might as well
MY BUILD
1998 Ford Explorer 2dr sport
1/0 Big 3 1/0 everything
Alpine cda-9884
Crescendo CZ components
(2) Crescendo bc2000's
(2) Jolt 150ah
(2) Yellow top optimas
(1) Juicebox black cherry addition
(1) Mechman 270 avbm
miss my bc5500 and (4) 15's
You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
I'm planning on cleaning the mass air flow sensor tomorrow morning. I have read that if the intake manifold gasket is leaking then it can cause this and to check by spraying starting fluid around the intake manifold while its running to see if it smoothes out the idle, but the problem with that is the truck idles fine most of the time and seems to only happen under acceleration. Wouldn't a bad intake manifold gasket cause a consistent problem?
Unfortunately I'm no mechanic. I chimed in my .02 because I have replaced 3 chevy fuel pumps, 1 ford, 1 dodge and they all caused these symptoms. New one cleared it all up!
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
Yea, I've replaced a few fuel pumps before, but it seemed like they just "died" and didnt cause any surging or jerking, but I have heard of these symptoms being a fuel pump. So I'm hesitant to throw $250 dollars and a bunch of work at this ya know? Lol
yes the fuel pump is dieing on you get it replace before you have to be towed home also replace fuel filter
Yea I'm not going to drive it anywhere till I fix the problem. I'm just looking for others experience and opinions about the issue before spending the time/money replacing the fuel pump. The filter was replaced about 15,000 miles ago, so that should be good still, but will probably replace that too anyway.
Thanks for your input man :good:
93 chevy surged and jerked and the 80's dodge ramcharger surged and jerked. The 98 ford would start off and on till it just died
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
if your suspecting the fuel pump, find a way to test the line pressure, that way your not replacing the pump on a hunch. if i remember correctly, those newer systems are usually supposed to run around 60 psi. i would double check that figure though.
Yea I was thinking of doing that as well. And I remember reading the pressure needs to be between 48-58 I believe so you were pretty close.
