TylerParrish Posted July 6, 2013 Report Posted July 6, 2013 Normally I add a switch to my remote wire to turn the amp on and off. I have a Rockford 360.1 and have it wired on a switch. Everything works fine, but the unit shuts off when I press the button to turn the amp on (it does turn the amp on, though). Do I have to run it to a relay, or does anyone know a way around this? What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
Carbon Posted July 6, 2013 Report Posted July 6, 2013 For a second at a glance I thought your name was TaylorFade. Is the switch wired inline? Is it a momentary switch or toggle?
TylerParrish Posted July 6, 2013 Author Report Posted July 6, 2013 It's inline with the remote wire, if that's what you mean. Also, I thought it was toggle, could be a momentary though. How would I be able to tell the difference? What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
mothra Posted July 6, 2013 Report Posted July 6, 2013 momentary switch is just for the moment you push it if nothing changes, nothing changes You don't know what you don't know, till you don't know
TylerParrish Posted July 6, 2013 Author Report Posted July 6, 2013 It's a toggle switch then. Since the remote is set to "out" on the bld, I didn't think it would have an effect on it What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
Carbon Posted July 6, 2013 Report Posted July 6, 2013 It's a toggle switch then. Since the remote is set to "out" on the bld, I didn't think it would have an effect on it It Should work as you intended it to but the switch may need power or grounding
TylerParrish Posted July 7, 2013 Author Report Posted July 7, 2013 Well, there's only 2 wires on it, so I'm not sure what the problem is, guess ill just have to play around with it until I fix it. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
Pioneerchuck Posted July 7, 2013 Report Posted July 7, 2013 a 2 wire switch is a simple switch its just the incoming source and the outgoing source. A 3 wire switch would be the input + the ground - and the output to the source. Does the 360.3 ever come back on or does it turn off and stay off?
TylerParrish Posted July 7, 2013 Author Report Posted July 7, 2013 a 2 wire switch is a simple switch its just the incoming source and the outgoing source. A 3 wire switch would be the input + the ground - and the output to the source. Does the 360.3 ever come back on or does it turn off and stay off? It's a 360.1. It's a simple 2 wire switch, and the BLD just stays off when the amp is on, and is on when the amp is off. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
