The alt is a tad longer from ear to ear so you have to oblong the top hole and file the top of the alt a tad bit to fit it in there and once you have the plug, just go to advances site and they'll have a photo showing you which wires are which so you can look at the plug and match them up for field and ground. The other difference is the position of the clock in relation to your stock alt so you may have to add some wire to the plug to make it longer.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
hmm... cool sounds very doable I'm going to take a look right now :D off to do homework in alts :D
<img src=http://i1332.photobucket.com/albums/w610/beastly666bassboy/IMG_9611192581855_zps9b9b76be.jpg border=0 alt= height="75" width="800">
Growing old is necessary... growing up is an option! Have fun or you might as well fall into a 6 foot deep hole. Its much easier to be smart and act stupid then it is to be stupid and act smart! You're only limited by your imagination! Stop limiting yourself! Optima yellow top6 guage cableJVC KD S36 headunitPower acoustik 1600w 750w rms @2 ohmsTwo MTX thunder 7000 10"sSealed box @4.04 ft^3Mojo Mat in the trunk Coming soon:1/0 awg cablebig 3... in 6 gauge(till i can get the money for 0)planet audio Crossover.2- 3.5's for the front.2- 6.5's for the doors2- 6x9's for the rear3- MB Quartz amps to power it all.1- 6" aeroport...soon! <p>My Log!
well now... got my car back on the road today... running strong as shit... I have one brake line to replace then she's good as new till I get money together for something newer.
I flipped my box around today and I honestly can't tell much of a difference. I'm sure the trunk rattles more but I can't make out any difference when I hits. so I think that's a moot point. but now when I fet the port I can just pull it out... cut my hole... paint it and throw my port on it :D now time to clean it out again :D
ok I just emailed mtx asking about proper box sizes for these subs. I'm hoping they'll get back to me shortly, the next couple days or so. because I'm thinking like yo... fuck this sealed box... I need a new build lmno.
how is that amp doing for you? i was wondering about them
actually dude I like it... its fricken strong. I'd say compared to the dual I had... I'd recommend this one twice over... it's nice too. it has an input throughput. the bass is clean as hell. literally no complaints. I'm considering the 6000w version for my next built. did you watch the video? yeah I only run maybe five db of bass boost... of 12db potential. the only complaint I have is the cheap looking silver W accent thing. ehh not my favorite thing... but for sound quality and over all value... DO IT! :D
so I found out thanx to mtx CS that I need 2.85 ft3 for my box... ssooooo.... that's my next build... :D
is that sealed or ported?
25d9cf71-fff8-4b67-a8f5-28c80d5ea859_zps7d3fe7f6-90c4-4939-b709-43f0e5812212_zps
2018 Honda Civic Sport Hatchback (build in progress)
NVX Sound Deadener (Front Doors)
Stinger FAST Rings
Stock Electrical
SSA Evil 6.5's Front Speakers
Stock rear speakers
MB Quart ONX4.80 speaker amp
Rockford Fosgate T-1500bdcp
DC Level 4 12" D1 @ 2-ohm
Box In Design Stage
Stock Radio
My Build Log
sealed... the spec sheet in pdf they sent me shows for 1 ft^3 for each sub to about 1.38 ft^3 so the one I'm working with is 1.38 per sub to get the best lows out of it... the port is going to be all external. 4x4 at about 11 inches! from torres. I finally got it figured out and am in the midst of the sketch up model... I just got done watching a movie so back to it :D
Doing a square external port? Would be a good time to play with that fiberglass and get all those corners rounded over.
But to be honest that gives you about less than 6 inches of squared port area per cubic foot, and that isn't gonna really cut it. For those 10's I would say a bare minimum of 11" squared per cubic foot of port area, otherwise it's gonna chuff and just plain not sound right
If you go aeroport you require less area to get the same results, so I would say 3 cubic foot total net enclosure with 1 full length 17" long 6" In Diameter Aero port
If you really want to stick with a square or slot port I would say bumping up to 3.5 cubic feet with a 6x6" with 18" length.
You have plenty of options, am not sure what your goals are or size constraints or what not
Stinger FAST Rings
Stock Electrical
Stock rear speakers
Box In Design Stage
Stock Radio
My Build Log
