kingsuv Posted July 12, 2013 Report Posted July 12, 2013 You don't need to fuse for any more then your system demands. Add up your total amperage draw, and fuse according. You need to remember, you are fusing to protect the battery from a dead short. Designing, building, and shipping boxes. Yahoo IM - kingsuv00If the listening level is too loud, please inform the driver, so he can promptly pull over, and let you out. not many cars can get me to pluggin my ears but this one.......damn. I mean the first minute is ok but that thing just really starts digging deeper and deeper in your earhole till you cant stand it no more. Seems like it does it with relative ease....16 12's on 8 amps.........gotta love it.
SMZ2 Posted July 12, 2013 Author Report Posted July 12, 2013 How would I calculated the draw from the amps? 2 skar 2500.1 and a mb quart 125.4 on a 270 amp alt 3 d3100s and a d3400. My Build Log!http://www.stevemead...nissan-xterror/ Check the Youtube Channel for Updates!http://www.youtube....ser/Xterror2002And Seller Feedbackhttp://www.stevemeadedesigns.com/board/topic/163179-bought-from-smz2/#entry2363713
SMZ2 Posted July 12, 2013 Author Report Posted July 12, 2013 If I should put a 300 amp fuse on each end of the wire would it be better for me just to run the 1/0 ofc? Also what size fuse would I need for the each of the skar amps. The mb quart has 3 40amp fuses. I'm just trying to do it right the first time. My Build Log!http://www.stevemead...nissan-xterror/ Check the Youtube Channel for Updates!http://www.youtube....ser/Xterror2002And Seller Feedbackhttp://www.stevemeadedesigns.com/board/topic/163179-bought-from-smz2/#entry2363713
SMZ2 Posted July 15, 2013 Author Report Posted July 15, 2013 Bump My Build Log!http://www.stevemead...nissan-xterror/ Check the Youtube Channel for Updates!http://www.youtube....ser/Xterror2002And Seller Feedbackhttp://www.stevemeadedesigns.com/board/topic/163179-bought-from-smz2/#entry2363713
lockdown801 Posted July 16, 2013 Report Posted July 16, 2013 Check this video out to help with amp draw. http://www.youtube.com/watch?v=H5MP5F-uJAw Look at your Skar owners manual and it should tell you what size fuse you need for the amplifiers. It looks like it says 250amp fuse and 500amp if you are strapping them. I would also run a external 120amp fuse to your MB quart amplifier. I dont care for the onboard fuses. Based on your amplifier it only has 1 positive and ground 1/0 gauge input. Unless you buy adapters you can only run a single 1/0 gauge cable to each one. I would say your amps will draw between 250 to 275 amps a piece and will only go up as voltage drops. I would run 3 1/0 gauge to your back battery bank with a 300 amp fuse on both ends. Then from the bank run 1 1/0 gauge to each Skar amp with a 250 amp fuse unless you strap them and probably a 4 or 8 gauge to your MB quart amp with a 120amp fuse,
kingsuv Posted July 16, 2013 Report Posted July 16, 2013 You don't need to fuse for any more then your system demands. Add up your total amperage draw, and fuse according. You need to remember, you are fusing to protect the battery from a dead short. Designing, building, and shipping boxes. Yahoo IM - kingsuv00If the listening level is too loud, please inform the driver, so he can promptly pull over, and let you out. not many cars can get me to pluggin my ears but this one.......damn. I mean the first minute is ok but that thing just really starts digging deeper and deeper in your earhole till you cant stand it no more. Seems like it does it with relative ease....16 12's on 8 amps.........gotta love it.
SMZ2 Posted July 16, 2013 Author Report Posted July 16, 2013 I plan to strap the skar amps My Build Log!http://www.stevemead...nissan-xterror/ Check the Youtube Channel for Updates!http://www.youtube....ser/Xterror2002And Seller Feedbackhttp://www.stevemeadedesigns.com/board/topic/163179-bought-from-smz2/#entry2363713
