Sky High Car Audio
Need help with Fuses for the 2/0
SMZ2
So I'm looking at getting the 2/0 and doing two power runs and a ground run. I am curious though if there are any fuse holders that will fit this huge wire. Also what would be the suggested fuse size for the runs to the back to a bank on 3 d3100s? I also need to check the rules on the local nspl competition and see if I can even use this big ole wire
Would need to use the basic ring terminal fuse holders.
The ones that skyhigh sells? What size fuse would you suggest at each end of the batteries?
\What size fuse would you suggest at each end of the batteries?
x2 im curious as well!
The spot with least resistance LOL.
I would ground to a rubber dildo if it had less resistance than a run of 4/0 wiring.
how many poeple work there 3 or 4 lol
At crescendo HQ? probably 2-3
At the sweatshop in china? 30,000 children
No Engine
350-400a fuse on the 2/0 should be plenty. That fuse size really depends on the output you have going from your alternator to the back as well. If you only have a 270a alt, a 300a fuse will be fine.
To my knowledge the 2/0 lugs won't fit on the Ring terminal style fuse holders. You won't be able to snap the cover back on, I tried it out before.
Gotta use them without the covers or take a dremel and trim the cover, but that is the only current option for fusing unless you go to toolmaker and get a custom fuse block made.
This... The fuse holders they sell fit the 1/0 fine as long as you crimp or solder it properly, but the 2/0 wouldn't fit in the holders. TM sounds like a good option, unless someone is inventive and makes their own cover.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Would you even have to fuse that thick of wire? It wouldn't burn up that easy anyway you know.
02 impala
VM-1
2 dc 12 xl's
RF t2500bdcp
Second skin damp pro
Kenwood head unit
240 mechman alt
d3400 in the front
d3100 in the rear
50ft Rockford fosgate ofc 1/0
