donpablo Posted July 7, 2013 Report Posted July 7, 2013 Right now im just using stock wire behind the deck running back to my amp But i want to switch it out and run the wires from the doors to the back with all new wire i just cant figure out how to get through the doors any one have any tips or a ford explorer they have done this on 2015 F-150 Platnuim
bcbrassard Posted July 8, 2013 Report Posted July 8, 2013 Its there a rubber wire lume that the stock wires are going thru now? Usually you just run new wires thru it an leave the stock one in place. It just takes time & patients to do it right. Door panel & speakers have to be removed, kicker panels to have access to the rubber boots and even sometimes taking the boots out of the doors and jam to get the new wires thru. Can be a pain but so worth it when run high power to good speakers. I hope this helps, good luck.
donpablo Posted July 8, 2013 Author Report Posted July 8, 2013 driver side looks to be the most trouble there is a plate blocking the whole side 2015 F-150 Platnuim
n8ball2013 Posted July 8, 2013 Report Posted July 8, 2013 get the biggest zip tie you can find and then pop the boot in the door jam. Fish the zip tie through tape wires on and pull it back through. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
