alaskanzx5 Posted July 8, 2013 Report Posted July 8, 2013 just got my 80prs set up in active mode. havent had more then 10-20 min play time on it but its sounds better already. i have a lot more tweaking and adjusting to do and it will take me days. im really liking the mute of different freq ranges so that i can listen to one specific range. helps a lot with trying to find the right balance. anyways, point of this is to get pointers from anyone and everyone. not looking for sq but squeezing every little bit out of this hu would be nice. t1500.1bdcp running 1 t2d415 set at 63hz with i think i went with a 16db slope t400.4 tweets set at 4k up with a 24db slope mids are set from 100hz-3.5k hz with a 24db slope. any pointers would be great thanks. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
audiolamb6 Posted July 8, 2013 Report Posted July 8, 2013 id try setting the slope a little less steep ur cutting them off pretty quick but if it is what u like go with it
alaskanzx5 Posted July 8, 2013 Author Report Posted July 8, 2013 messed around with it a little bit more today. lowered the slope on the mids and highs some and got the eq a little more flat but to me sounding better. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
alaskanzx5 Posted July 8, 2013 Author Report Posted July 8, 2013 changed the crossover points around a bit, sub is at 63hz with a 16db slope, mid is at 100hz 12db slope and 3.15khz 12db slope, tweet is at 4k 12db slope. lacing a little mid bass right now, going to quite down my tweets a bit to see if i can get the mids to stand out a bit more. i now im not getting much between 63hz-100hz right now but unless i decide to put in 8 in my door i wont be able to change that. the mids are there but the tweets seem to be drowning them out a little bit. when adjusting an eq is it ok to go into the positives on it? i have always been told to stay at 0 or less to keep the signal clean. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
shogen Posted July 8, 2013 Report Posted July 8, 2013 you could turn the gain down on the amp for the tweets.... makes life easier than trying to EQ them down or cut them in the HU... just a suggestion changed the crossover points around a bit, sub is at 63hz with a 16db slope, mid is at 100hz 12db slope and 3.15khz 12db slope, tweet is at 4k 12db slope. lacing a little mid bass right now, going to quite down my tweets a bit to see if i can get the mids to stand out a bit more. i now im not getting much between 63hz-100hz right now but unless i decide to put in 8 in my door i wont be able to change that. the mids are there but the tweets seem to be drowning them out a little bit. when adjusting an eq is it ok to go into the positives on it? i have always been told to stay at 0 or less to keep the signal clean. Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear) beaker- I know this sounds like a lot of anime bullshit, but it is true.
fox_racin4 Posted July 8, 2013 Report Posted July 8, 2013 Pioneer decks dont clip unless you have everything turned way up at volume 62 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
audiolamb6 Posted July 8, 2013 Report Posted July 8, 2013 ive been thinking bout tryin the auto eq . ive not messed with my eq yet got it set flat
alaskanzx5 Posted July 8, 2013 Author Report Posted July 8, 2013 Pioneer decks dont clip unless you have everything turned way up at volume 62 dd-1 tested 62/62 no clip. so i guess that mean it would be ok for me to adjust the mids above 0 if needed. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
alaskanzx5 Posted July 8, 2013 Author Report Posted July 8, 2013 you could turn the gain down on the amp for the tweets.... makes life easier than trying to EQ them down or cut them in the HU... just a suggestion changed the crossover points around a bit, sub is at 63hz with a 16db slope, mid is at 100hz 12db slope and 3.15khz 12db slope, tweet is at 4k 12db slope. lacing a little mid bass right now, going to quite down my tweets a bit to see if i can get the mids to stand out a bit more. i now im not getting much between 63hz-100hz right now but unless i decide to put in 8 in my door i wont be able to change that. the mids are there but the tweets seem to be drowning them out a little bit. when adjusting an eq is it ok to go into the positives on it? i have always been told to stay at 0 or less to keep the signal clean. 5volt preouts on the hu, gain is less then a hair up. set with a dd-1 t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
