how much can a recone increase performance
Lead wires burning in two are a issue with Re . All it takes is a split second of clipping an there done. You can get triple lead wires on psi recone
One f****** time is all it took! and they were such beastly little subs too for 600rms.
Do lead wires have to be stitched to the spider? Because idk how to do that and if the upgrade for the sub costs too much i'm thinking of just buying some
lead wires and re soldering them.
One f$$**** time is all it took! and they were such beastly little subs too for 600rms.
Well, upgrading the motor coil and basket means you're replacing every part of the sub so...buying a new sub would be just as effective and around the same price
Well I would like some more experience in building subs. This guy is selling a tc sounds motor 4" coil. How much would a basket for a 12" cost that would fit that magnet?
coil is what determines power for the most part. 2.5 inch coil right? I wouldnt expect it to take more than 1000 rms. at most. would be more comfortable in the 7-800 rasnge.
I think it has a 3" coil
The frame brand new is about $85, or if you just want a 12 spoke they are about $50. Then you would also need coil, cone/ surround, spiders (& spacer w/ TI frame), shims, glue, and a gasket & dust cap.
PSI sells all of this, except the TC frame, which can be found on eBay.
But a heads up, it's kinda expensive to do all this, at least more so than I thought. Plus, if you've never done it, you really want to have someone there with experience to help you out. It's all pretty simple, but also very easy to mess up.
But yeah if your determined to build your own sub, PSi is the place to go for help and parts. They are a little high, but have quality parts, and will help you out all they possibly can. My advice would be to use that TC motor, or any motor that is proven, powerful, and easy to find parts for. It will be much easier overall if you do. The RE's can be built to be nice, but is that really what you want? That's the main thing I would consider before making any decisions.
Hope that was at least somewhat helpful.
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
4th Order wall 4 - 15's
on a DC 5.0K 2 DC 5.0K's
Solo X 15 (v.2) Sub Build
They sow them to the spiders to prevent them slapping the cone an making noise . I prefer them to be sowed up my self
Experimenting with coil/motor configs sure is fun. But be ready to play around with enclosure tuning,ssf tuning ect. Most parameters will change after a re-cone,and it may never be as loud as before in the same enclosure on the same amp,especially with an even more stiffer suspension and possibly higher fs.
  • Who's Online   0 Members, 0 Anonymous, 1737 Guests (See full list)
