Beginner build going big, need answers
Hello im fairly new to car audio, right now i have 2 12" COMP kickers with a DB.500 Rockford fosgate amp, but i got quiet a bit of money and ima go all out.
im gonna be ordering:
4 15" Rockford T2's
2 Rockford T2500
2-3 XS 2400 (might get different)
320 Amp DC Power alt
Pioneer DEH-80PRS(5 volt)
This is all going into a 1999 Suburban
What my question is, will i need more battery support to power all of this?? will i need more than 1 alternator? or a bigger battery, im not quiet sure. please help!!! or give advice
320a dc alt on its own is fine if you the batt to back it up, if you want to go over 5k of power you'll need another 320a alt
The 2400's won't cut it idd get the 3100
Min needed is 1 up front and 3 in rear(4 rear is better 2per amp)
2 runs of 0g from front to back
Other then that just make sure you can fit everything where you want it
Idd get some designs down first and make sure your happy with them before you buy anything
Like john253a said id get two 320s if u can swing it
My setup,
Digital Designs M80
3 Re audio 10's ported tuned to 36 hz
Kenwood x-696
SHCA 0 gauge
Polk audio coax running off hu
I wouldn't get Rockford subs personally unless you are set on those.
GLWB
agreed
My setup,
Digital Designs M80
Kenwood x-696
SHCA 0 gauge
What's Wrong with the Rockford T2? I have a friend with one and it sounded like a beast, and I got a budget of like 6 grand, so I'm trying to work around that until I can get more money, is it possible i can run all that but buying a few more batteries?
You can do so much more than that if 6k is your budget
FI BL18 Build Log: CLICK HERE!!
2003 Explorer Sport:
FI BL18
SoundQubed 2200 at 0.7ohm
Pioneer DEH-2500UI
Pioneer 6 x 8s
Rockford Fosgate 6 x 9s
5 ft^3 box at 35hz
Lots of Mega Mat
SkyHighCarAudio_zpse6b4e501.png3abb2365-8d29-422d-a446-efa7a74b8dba_zps70e62980.jpgFILogo_zps400b37c1.jpg
We all Like R.F. , but you can do so much more with the same cost. R.F. subs you pay for the name mostly .
"Walmart Where Car Audio Is Both Funny and Sad" "The weak are meat, and the strong do eat..."
  • Who's Online   1 Member, 0 Anonymous, 4336 Guests (See full list)
