vw passat Posted July 20, 2013 Report Posted July 20, 2013 hi smd im very sad ):iv just finish the 15'' box with 3.25 cubes and 16sq port area per foot at 40hz and it came with port noise when i hit the lows ): like 29hz port noise 27hz port noise and i think even the 36hz is not good. im very very confused i dont know what im going to do can someone help me pls?
Hugh G. Rection Posted July 20, 2013 Report Posted July 20, 2013 hi smd im very sad ): iv just finish the 15'' box with 3.25 cubes and 16sq port area per foot at 40hz and it came with port noise when i hit the lows ): like 29hz port noise 27hz port noise and i think even the 36hz is not good. im very very confused i dont know what im going to do can someone help me pls? i very seriously doubt that what your hearing is port noise. it sounds to me that you dont need to be playing that far below port. why in the fuckin' world would you tune at 40hz if your wanting to play down into the 20's? Owner of BigAss Ports
will77530 Posted July 20, 2013 Report Posted July 20, 2013 if you tune to 40, you shouldnt even try to touch anything below 35 plain and simple i give it a month before you blow your sub
vw passat Posted July 20, 2013 Author Report Posted July 20, 2013 i have mine 15'' is tuned to 40hz and i play at 26hz but with aero port this box that iv made is my friend's box. do u think i need to make a little bit of port area per foot? tx
Hugh G. Rection Posted July 20, 2013 Report Posted July 20, 2013 i have mine 15'' is tuned to 40hz and i play at 26hz but with aero port this box that iv made is my friend's box. do u think i need to make a little bit of port area per foot? tx lower port area will definitely increase the bandwidth of the enclosure, but no matter how you polish the turd, at the end of the day it is still a turd. Owner of BigAss Ports
vw passat Posted July 20, 2013 Author Report Posted July 20, 2013 so what can i do i need a box for meter and daily. tx guys
SnowDrifter Posted July 20, 2013 Report Posted July 20, 2013 Box is tuned too high for what you are wanting to play.But lets rule out other things before you start on your next enclosure. Could you post up detailed box specs? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
vw passat Posted July 20, 2013 Author Report Posted July 20, 2013 http://i40.tinypic.com/5bfp3.png tx again for helping me
SnowDrifter Posted July 20, 2013 Report Posted July 20, 2013 Box looks fine at a glance, I would have braced it a bit but that's just me. I will ask you this though: How in the world do you plan on getting accuracy to the 1/1000 of an inch? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
vw passat Posted July 20, 2013 Author Report Posted July 20, 2013 i didnt understand what u want to tell me sry
