brian85578 Posted July 21, 2013 Report Share Posted July 21, 2013 Question if a box is tuned to 31 or say 35 what range will it play like 31 to 80 and 35 to 80 Link to comment Share on other sites More sharing options...
SnowDrifter Posted July 21, 2013 Report Share Posted July 21, 2013 There is no simple answer More to it than just tuning frequency. My box is typically tuned in the high 20s (adjustable tuning) and will play from 25-26 up to 63-65. Some people with low tuned boxes can't play that high. It just depends ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
slowfkncar Posted July 22, 2013 Report Share Posted July 22, 2013 Generally,to have a wider frequency slope in a ported enclosure you need to have less port area. And that answer alone will depend on enclosure net size,cabin size,subwoofer loading,enclosure tuning,subwoofer Q. Mostly trial & error. Link to comment Share on other sites More sharing options...
bkolfo4 Posted July 23, 2013 Report Share Posted July 23, 2013 Port area does NOT determine the frequency range! And tuning does not determine how high the sub can play. Higher tuning can create a peak at the higher tuning frequency, but that is NOT the same thing as the port limiting the upper frequency range. Think about a home speaker - my cabinets are tuned to 30 and play up to 1.8 kHz. Not sure where tuning limits the upper frequency response started. . . Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz. Link to comment Share on other sites More sharing options...
