Alec George Posted July 22, 2013 Report Posted July 22, 2013 I'm new to the forum so i'm sorry if i mess any of this up. But with that being said, i have two 2ohm DVC pioneer champion series pros, one 4ohm DVC sundown audio sa-12, and an alpine MRP-M1000. i have 0 gauge ran to the back into a distribution block. I am planning a custom build and i want to know what are my best options for boxes? I have it all in a 2005 Jeep Liberty, so my space is limited. I would like to keep it all in the trunk. I plan on pushing the sundown with the Alpine amp and finding another amp for the pioneers. I plan on building a bandpass box, i am very good with the hands on work, but not so good with the technical part (calculating box specs). I need recommendations on which route i should go with a box, or boxes. Also what would you recommend to power everything. Right now i have complete stock electrical system. I plan on getting some XS power batteries but which one and how many should i get? i don't really want to upgrade my alternator at this point if not necessary. If someone could help me out with my box specs it would be greatly appreciated, i'm very good with google sketch up and am gonna use that program to mock build the box, and get the measurements from to cut and construct the box(es). Any help or recommendations is very appreciated! thank you
jarrius Posted July 22, 2013 Report Posted July 22, 2013 Ok first thing is you don't run 2 totally different types of subs together. Sound will be off amount of power will be off and you will not like it. Second thing is if I'm not mistaken band pass boxes take a lot of space when they are correct. Third thing is you need to figure out if you want to run the 2 pioneer or the 1 sa(I would do the 1sa). After that go out to your car and get the max mesurements you can use length width and hight. Then make another thread in the subwoofer/encloser section saying what woofer/woofers you want to use if you want a bandpass or regular ported box and then post your max mesurements and some one will get back to you with a design for what you have chosen. As for electrical that alpine is only stable at 2ohms if I'm correct and only puts out about 500w rms. so if you do want to use it you should be fine on stock electrical. Other then what I stated I don't know much about electrical yes still learning on that...... Good luck and welcome to the fourm 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
