SnowDrifter Posted July 26, 2013 Report Posted July 26, 2013 Ahhhh ok. Those fuses are 80a each?You should be fine. I doubt you'll pop them unless you are clipping a ton. If you do: stick (4) 100amp fuses in there and you should be good to go ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
_94fleet Posted July 26, 2013 Author Report Posted July 26, 2013 no they are 40 ea B2 Zero.7r - Soundqubed 4-120 - Digital Designs 9918 - Rockford Fosgate T1 5.25" - Deh-80prs - XS Power D3400 XS Power XP3000 - Mechman 250A - Big3
SnowDrifter Posted July 26, 2013 Report Posted July 26, 2013 In that case I'd replace them. I can just about guarantee they will blow lolIf you don't have a volt meter in your car: invest in one. They are good to have, especially in your case where you have the stock alt and you need to worry about drop ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
_94fleet Posted July 26, 2013 Author Report Posted July 26, 2013 i have a voltmeter just need to install it. will prob be doing that today. B2 Zero.7r - Soundqubed 4-120 - Digital Designs 9918 - Rockford Fosgate T1 5.25" - Deh-80prs - XS Power D3400 XS Power XP3000 - Mechman 250A - Big3
SnowDrifter Posted July 26, 2013 Report Posted July 26, 2013 Ok cool. If at all possible, run the positive and negative leads to the pack and put them into the power inputs on the amp along with the power wire. That way you see what the amp sees. Don't forget to fuse it too ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
_94fleet Posted July 26, 2013 Author Report Posted July 26, 2013 will def do that. what size fuse? im sure its a smaller fuse. B2 Zero.7r - Soundqubed 4-120 - Digital Designs 9918 - Rockford Fosgate T1 5.25" - Deh-80prs - XS Power D3400 XS Power XP3000 - Mechman 250A - Big3
Karkov Posted July 26, 2013 Report Posted July 26, 2013 Might as well wait till they blow to replace them, but yea go with 100's then, buy them now though, lol 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0
SnowDrifter Posted July 26, 2013 Report Posted July 26, 2013 I used a 3a fuse for mine. In all honesty you could use a 1a fuse. Most volt meters only draw a couple milliamps anyway.Here's what I use. Use a butt connector to attach it to your lead wire to the fuse holder, then stick the wire from the fuse holder right into the amphttp://www.autozone.com/autozone/accessories/Cooper-Bussmann-ATC-fuse-holder/_/N-25gq?itemIdentifier=32415_0_0_ ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
_94fleet Posted July 26, 2013 Author Report Posted July 26, 2013 ok. appreciate all the help. B2 Zero.7r - Soundqubed 4-120 - Digital Designs 9918 - Rockford Fosgate T1 5.25" - Deh-80prs - XS Power D3400 XS Power XP3000 - Mechman 250A - Big3
NancyDrew Posted August 3, 2013 Report Posted August 3, 2013 The fuses should not be rated any higher then its max load. Wait to see if they fail at all. If you put to high of a fuse, and they do need to fail they may not in time to protect your really nice lookin amp bro.
