Guest Nismofreak
3k @ 1ohm?
no way
compare it to a gp 3000d
the gp looks so much better built then that aq amp but the gp300d is so underrated
nm...
Edited by Nismofreak
no way
nm...
the crunch puts out the major power on 16v...also the AQ does over 3k on 16v..here are the test results scrowl down some
http://www.caraudio.com/forum/showthread.p...9633&page=5
MMM BASS OATS..ITS WHAT I HAVE FOR BREAKFAST
2 AudioQue HDC3 18'' subs
Rockford Fosgate T1 6.5 mids
MMATS 2000.05
XS Power D1200
Knukonceptz 1/0
Pioneer Premier DEH-P490iB
" Shit I can roll a blunt better than those bitches in Havana!"- Uncle Elroy
Guest Nismofreak
well accord did a test on his colossus and got 3,900 from them
uh o well
edit- looked at it. has the same type of design as the gp3000d
just look at the quality.
The AQ
The Crunch
now tell me the major difference in quality that you see tom
MMATS 2000.05
XS Power D1200
Knukonceptz 1/0
bry look at my edit. my bad
no prob just pointing out the boards...was talking and uploading so i didnt check for updates on this thread
MMATS 2000.05
XS Power D1200
Knukonceptz 1/0
Guest Nismofreak
yah clicked on the pic to make it bigger. yah I noticed that
The Colossus and Thor are too expensive, I am going to keep it under $400 for this upgrade.
I am also looking at the Lanzar OPTI2000, I know they put out more then they are rated and it is cheap.
I'm thinking about the AQ but if the 1200D is $249 how is the 2200D going to be less then $400?
Edited by REVOK1NER
2000 Ford Explorer XLT
-20" RVM "Buck" Wheels
-2.5% Tint
-CompuStar Vizion Alarm
-(4) Infinity Kappa 680.7cs 5x7"
-1 XStatic BatCap Model 300
-2 18" DC LVL 4's
-Amps are undecided
Either way, if you want a 2000wrms amp its going to ruffly take the same electrical upgrades as any other amp that puts out its RATED power.
example..
power acoustik Power Acoustik OV1-5500D vs a t20001bd fosgate.
The PA is rated with 5 30 amp fuses (150 amps total)
The RF is rated with 1 250 amp fuse.
We all know the PA is not going to make the 3200wrms by 1 @ 1ohm it may be lucky to do it in peak (but thats a whole nother story) but on the RF amp however it says it is 2000rms by 1 @ 1ohm and it will do that and some more, so it will need the extra amperage to have it play properly
Most likely the RF amp will walk all over the PA with the proper electrical upgrades.
