Question on strapping amps
brent379
So right now I'm running 4 10s at a 1 ohm load of an aq2200d. I want more power and was thinking about getting another aq2200d and strapping them but audioque says to run them at 2 ohm.
My question is does strapping amps change the final ohm load?? If not what happens if you run amps strapped under the rated ohm load??
When you strap, You have to raise the final ohm load, it gets split in half, for each amp. Wiring at two ( 2 ) will make each amp see one ohm load, Or as in strapping at one, each amp see's .5. And so on.
So whatever your final ohm load on your subs is, is split to what each amp see's. If that makes any sense at all, to you.
And running strapped under rated ohm load, will void warranty. And, can potentially blow your amp. While its not recomended, you can get away with it.
I personally, am gonna strap at 1.4, so each amp see's .7, but that's just me. And its my own fault if something shits the bed. But with doing that, you have to make sure your electrical is very good.
*06 330i - Sundern x12 - saz-3500*
*91 Foxbody V1 S-Trim Notch*
Oooooooo ok I got it now. So then if I wire the subs to a 4 ohm load then each amp would see 2 ohm then right??? If so then tht would be perfect!!
Yep. You got it.
Not sure if ya know how to strap or not. But might as well throw it here.
Connect negatives on both amps together, with jumper wires.
Master amp, with your gain settings, and switch set to master is your positive sub wire output.
Slave amp, slave switch, is your negative sub wire output. ( But you will be using the positive terminals on this amp for your negative sub wires. )
And thats basically that, lol. Any other question's, we're here for that!
When ur talking about jumping te negative from amp to amp your talking about the speaker terminal negatives right??
How do you hook up the rcas?
  • Who's Online   0 Members, 0 Anonymous, 314 Guests (See full list)
