dsw422 Posted August 1, 2013 Report Posted August 1, 2013 Iv got an autotek 1500.1 wired to 1 ohm.. i noticed a smell yesturday and popped my trunk. I couldnt even keep my hand on the amp.. y is it doibg this??? 2014 Ford Focus SE Sedan Factory Sony 10 Speaker Sound System 1994 Ford Bronco Dual head unit (i kno) Sony door speakers Kenwood Rear Speakers Custom Center console in the works. will house an NVX NSW10" https://m.facebook.com/WinnsCustomCarAudio/
Karkov Posted August 1, 2013 Report Posted August 1, 2013 Might only be rated to go down to 2 ohms? 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0
TITUS1985 Posted August 1, 2013 Report Posted August 1, 2013 The amp is rated at 1 ohm ... http://www.onlinecarstereo.com/CarAudio/p_13932_Autotek_MX-15001.aspx Might just have pore cooling system ... Or it could be bad, I hate saying that because nobody wants to hear it. But, with that said even my $1600 Audison amp was bad :/ so it can happen.. Best of luck with the amp man.
DJ_Stubbs Posted August 1, 2013 Report Posted August 1, 2013 Is it plugged into the right settings and everything? What kind of sub? 2007 Dodge Caliber SXT 2.0L Flowmaster Single muffler + Tip 4 SoundQubed 6x9s 3-way PolkAudio PA660.4 2 MB Quart Tweeters 2 4" MB Quart 2-way New 8" coming soon!
wccfan12 Posted August 1, 2013 Report Posted August 1, 2013 What is your electrical like? How did you set the gain? What kind of music was playing when this happened and how long were u playing music? Were your subs hot or just the amp? Is your ground nice and tight to a point on bare metal with the paint sanded away? THE ANTHRACITE DYC CRUISER -Fully dipped anthracite grey pt cruiser -4 skar vvx 12's (version 1) -Mechman 240 amp alt -Big three in Cadence 1/0 -1 deka intimidator g31 blacktop under the hood -1 C&D 140ah Batt & 1 C&D 55ah batt in the rear -Re audio/soundstream mids and highs -Hifonics Zues 600.4 -DC Audio 3.5k
dsw422 Posted August 1, 2013 Author Report Posted August 1, 2013 Thanks all the replies. Have all 4ga power and ground with a good ground. Electrical system charges at 13.7 volts.I was playing for about 25 minutes. It is powering 4 kicker comp 10s. I was playing dubstep and hiphop.. i controll gain with bass knob never more than 3/4 way up. The input level is 2 volts. Thanks 2014 Ford Focus SE Sedan Factory Sony 10 Speaker Sound System 1994 Ford Bronco Dual head unit (i kno) Sony door speakers Kenwood Rear Speakers Custom Center console in the works. will house an NVX NSW10" https://m.facebook.com/WinnsCustomCarAudio/
Guest Posted August 1, 2013 Report Posted August 1, 2013 are you using the remote wired knob that came with the amp? cause it could be a bass boost knob, instead of a gain attenuation knob which is better IMO. unless you're using a pac lc-1 or something similar, which is a gain attenuator. are you SURE you're wired to 1 ohm? have you verified this with a multimeter? you could just be overdriving the amp if you are clipping it hard.
SnowDrifter Posted August 6, 2013 Report Posted August 6, 2013 Ok. So you charge at 13.7 what do you drop to if you measure the voltage at the amp? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Hammer Knock Posted August 10, 2013 Report Posted August 10, 2013 tuned for no distortion?? if the car doesn't stall, you have enough voltage. DEH-6400BT BC3500D on 2 x 12" Lanzar Opti1233d QBOMB 4.5cu 1/0 awg, Lanzar AMPKIT0 Singer 275 + LCAKT50DBL
Lifted2000Ford4x4 Posted August 13, 2013 Report Posted August 13, 2013 gain too high, bad ground, ohm load too low.
