Amps pop.... Tried all kinds of stuff..
walwalka
Try pulling remote wire out of amp..jump small wire from positive of amp to remote turn it on then remove jumper wire.see if amp still dose it.if so maybe amp has a internal issue.
That's what I'll do tomorrow before work. Will report back.
2010 Honda Civic LX / Deck: Kenwood DDX371 / Front Highs: Crescendo RTS-1 / Front Mids: Silver Flute 6.5's / 4 channel: DC Audio 90.4 / Sub: Fi 15in SP4v2 / Sub amp: Taramps HD 5000 / Power wire: Knukonceptz OFC 1/0 / Deadener: Audio Technix 60 mil / Batteries: XS Power D5100R / Rear bank: TBD / Alternator: Singer 240a hairpin
Sure does. I'm brain dead this week too. We had paid a company to come in at work and configure and deploy new network equipment on Monday. Well they didn't configure it right and it didn't work. Well basically the said screw yourself. So I've spent the last week fixing the configs and figuring out what they didn't do. Mean while taking a crash course in routing because that's not my thing.... Lol. I couldn't troubleshoot a potato right now.
does it pop louder depending on what the volume was set at. like is the pop louder at 60% volume compared to 20%?
2007 Ford Focus SES Hatchback
Pioneer HU
4 Digital Designs 9515i's in a B pillar.
2 Soundstream XXX 15K's (running at 16 volts)
Soundstream Mids/Highs in custom door panels (getting rebuilt soon)
Soundstream TA2.160 and TA2.400
Sky High and KNU wiring
3 Banks of Maxwell caps
Winston Lithium (not a fan)
Bump4Life 250 Amp Alt. aka USAlternators
Soundstream Focus and Avenger Build Log
Instagram @p4linnovation
YouTube: Team Blowin Loud
When exactly did they start doing that?
FI BL18 Build Log: CLICK HERE!!
2003 Explorer Sport:
FI BL18
SoundQubed 2200 at 0.7ohm
Pioneer DEH-2500UI
Pioneer 6 x 8s
Rockford Fosgate 6 x 9s
5 ft^3 box at 35hz
Lots of Mega Mat
SkyHighCarAudio_zpse6b4e501.png3abb2365-8d29-422d-a446-efa7a74b8dba_zps70e62980.jpgFILogo_zps400b37c1.jpg
I think I have my sequencing right so let me try to get it right: Usually the pop happens because the amps have something up stream that turn off before they do. So- you said you don't have an EQ or anything between the head unit and amps.... leaving only the head unit.
IF you have your head unit OFF and just put a jumper wire from positive 12 volts and remote turn on to your amps (unplug your current ones) do you still get turn on and turn off pop? If you do, then it is the amp. If you don't, then your head unit is turning off before the amps turn off. That leaves a signal or power across your rcas and when the amps go off- pop.
I have different brands of amps, processors and eqs. What that means is that I had timing issues with turn on and turn off delay as well as a pop or thud. I found some processors that had both turn on and turn off delay. The processors stay on for like 10 seconds after the head unit goes off and isolates the equipment. Then the turn off time can be adjusted for different equipment. So- amps go off first (quiet) and then the eq's go off second where they can't put any noise into the amps before shut down.
So saying all of that: hook up a proper relay between your head unit's remote wire and your amps, check the ground on your head unit, you MAY want to get a 12 volt noise filter for the remote wire too.
Test what is making the pop- the amps or the HU.
12 - 12"s in the STAY PUFT 1989 Chevy Astro
Build & Comment Log
Un-Interrupted Build Log
YouTube Channel
Chevy Trailblazer 5.1 Dolby Digital DTS Install
You have a beard of a mysterious sea captain. I would follow you to hell and back.
It appears that the pop is in the amp. I turned the car off. Unhooked the remote, then I jumped the remote from 12v and it did the same thing. So I'm just blaming it on the hifonics amp having a hard shutoff. As for the four channel. I will test it later. It may just be getting old. Its done it since I've installed it.
I've played with it more, it seems like the hifonics amp is the only one that will "pop" per-say.. The Alpine sounds like the amp turning off. Not a pop, but a lot like when you unplug a microphone. Just really really quiet. That disconnection sound. Honestly neither sounds are loud at all, they are both fairly quiet.
  • Who's Online   0 Members, 0 Anonymous, 881 Guests (See full list)
