Giuseqpe Posted August 4, 2013 Report Posted August 4, 2013 Hi, I can get 2 cheap stinger batteries used from a friend, so I'm probably going to buy them. I'm wondering if I can run those two with a xs power battery or something later in the future? Or should I run all stinger? This is no VS thread. Just used xs as an example:) Thanks
k3n12ock Posted August 4, 2013 Report Posted August 4, 2013 Should work without any issues. 05 xB - (2) EVIL 18s - (2) BC3500s - NO WALL Channel 1: http://www.youtube.com/k3n12ock Channel 2: http://www.youtube.com/MrK3n12ock2
reg93f150 Posted August 4, 2013 Report Posted August 4, 2013 people often say, that 2 brands of batterys shouldent be used in the same application.. one reason is that different brand batterys float at different charges and such, and it could possibly make the life of one of the batterys shorter then what it would be normally. ALL CREDIT TO XX1 FOR DC BANNER down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
Giuseqpe Posted August 4, 2013 Author Report Posted August 4, 2013 I see, but aint all the dry cell batteries the same?
Watch the bass Posted August 4, 2013 Report Posted August 4, 2013 No their not the same. In this case i want quote Nathan, who stated longer time ago "only Stinger batt´s are comparebale with XS-batt´s", think he ment the technique. "in the abundance of water, the fool is thirsty" Bob Marley
bighossf150 Posted August 4, 2013 Report Posted August 4, 2013 It'll be fine, I run deka and xs Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
Guest DC Power Kyle Posted August 4, 2013 Report Posted August 4, 2013 I run XS and Odyssey and Stinger is made by odyssey so you'll be fine.
Giuseqpe Posted August 4, 2013 Author Report Posted August 4, 2013 Thanks for the answers:) Guess I'll buy the stinger batteries now and upgrade slowly:)
Katt Posted August 4, 2013 Report Posted August 4, 2013 people often say, that 2 brands of batterys shouldent be used in the same application.. one reason is that different brand batterys float at different charges and such, and it could possibly make the life of one of the batterys shorter then what it would be normally. I have yet to hear this. I have heard the don't mix agm with lead acid though. Don't see why you couldn't mix brand a agm with brand b agm. Same with lead acid a, and b. *06 330i - Sundern x12 - saz-3500* *91 Foxbody V1 S-Trim Notch*
