any of you gents into, or knowledgeable in woodworking (specifically veneering)?
We call it Spray 90, H.D., Lowes, Walmart all have it. It comes in a aerosol can, black and green. It's on the same isle as the other glues and such. Coat the plastic surface, let it tack up good. Then another coat on the plastic, let it tack. Then one LIGHT coat on the veneer, let it tack, then apply.
Dog24Fret
Like Big-A said using contact cement is the best way really. The spray adhesive as Jay L mentioned will work but if you live in high heat area it will come undone and ruin the veneer. In this case use a way to clamp or press the veneer to the piece or carefully use a hot iron. But as always test a small piece working in thin layers to avoid bubbling or bleed through. This is in my own experience and also cabinet making. What type of veneer you using? Posting from phone so hope this comes out right.
I don't think contact cements would work well in a hot car in the summer. I would think the heat would make the glue soft an it could peel. I'm almost for sure tb3 wood glue will work if you prep it good . Test it an see I would try that first if it was my project just because its water cleanable if you get messy plus no harsh fumes. And the cheapest too witch is a plus in my book lol
3m tape is also an option. That's what's used on wood grain stuff for your car that I've delt with. Or it's similar stuff and it sticks good if you clean the plastic right
Hey Journeyman Cabinet maker here. If it is going to be in heat know of the products mentioned above will work. Try going to cabinet supply shop and see if they have any water based contact cement. Any contact adhesive with lacquer or any oil based product in it will delaminate in hot car. Make sure you get 100% coverage around the edges of laminate, and 75% in the center area. The veneer has a tendency to delaminate if you do not get full coverage on edges do about 2 1/2 inches around edges. This includes the box also. Spray in a sprayer is best for this application.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
wow, lots of AWESOME info in here, thank you all, seriously. I use dap weldwood contact adhesive for all my upholstery stuff, and it works great. its a solvent based contact cement. my initial research indicated NOT to use it for this, as outgassing could cause bubbling, even months later. the water based contact cement may be an option. one thing I neglected to mention (sorry), is tthis will be stained, and poly coated. will either of these cause an interaction with contact adhesive, or even loctite?
