mbdblue Posted August 10, 2013 Report Posted August 10, 2013 potentially, you could have had your old setup wired at a lower resistance than this one....knowing it or not. You also mentioned you kept the same box which (if it was built more for your old subs) could sound worse with new subs and old box. my guess would be your wiring. AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
Joebro63 Posted August 10, 2013 Author Report Posted August 10, 2013 Box just cheap mass produced crap
jarrius Posted August 11, 2013 Report Posted August 11, 2013 Box just cheap mass produced crapWell there is one major problem. You need to build a box for them prefabs are not good boxes to use at all then make even the higest end subs sound bad. A custom box with even crapy subs will sound better the. A prefab with highend subs 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
Joebro63 Posted August 13, 2013 Author Report Posted August 13, 2013 Okay, so for building my ported enclosure, the specified port length seems much shorter than what I've seen how do I correctly build the port? And what can be used to make a circle port or is slot better
That1Kid Posted August 13, 2013 Report Posted August 13, 2013 The gain isn't a volume knob. Set your gain with a DD1 -98' Ford Expedition (Rest in Peace) -AVH-P3300BT -Crescendo BC5500 -4 18" DC m2 Level 3.
