DCdakota Posted August 12, 2013 Report Share Posted August 12, 2013 I'm about to build a new box, my level 4 has a fs of 30.6 and I want to play lows (20-30) very well and not ruin my 30-45Hz tones... My box now is tuned to about 40 and my sub sounds like its about to bottom out in the 27Hz area does that sound right since the fs is 30? ill admit I'm no pro box designer so could someone help me? Link to comment Share on other sites More sharing options...
banginhummer Posted August 12, 2013 Report Share Posted August 12, 2013 What do you have your subsonic at? I always set it 10hz under tuning *Hummer H3* HeadUnit Pioneer AVH-X4600BT Mids and Highs 8-CT Sounds Pro 8" 8ohm 4-CT Sounds Pro Tweeters Amplifiers 1-CT Sounds 125.4 1-CT Sounds 60.4 1-CT Sounds 7000.1 Electrical 3-Runs of 1/0 CT Sounds 8-XS Power D3100 3-Iraggi 300 amp Alternators Subwoofers 4-SQ Hdc3 15" Subwoofers (Soon to be 4 15" Ct Sounds EXO) Link to comment Share on other sites More sharing options...
TeamHT Posted August 12, 2013 Report Share Posted August 12, 2013 What power is being used and in what vehicle? SSF is not a wall, and generally should be set a little below tuning. FS is the free air resonance so once the sub is placed in an enclosure that specific number alone doesn't really do much for you. You will want to plot and calculate for your f3. I like the level 4s. If you're really wanting to play down to 27 I'd probably tune to about 33Hz Tell me...does this smell like chloroform to you? Link to comment Share on other sites More sharing options...
STEALTH808 Posted August 12, 2013 Report Share Posted August 12, 2013 What power is being used and in what vehicle? SSF is not a wall, and generally should be set a little below tuning. FS is the free air resonance so once the sub is placed in an enclosure that specific number alone doesn't really do much for you. You will want to plot and calculate for your f3. I like the level 4s. If you're really wanting to play down to 27 I'd probably tune to about 33Hz he wants to play 20-30hz. TEAM SUNDOWN HAWAIIHAWAIICARAUDIO.NET 150Db Club 160Db club in the future I see krakin as a threat Link to comment Share on other sites More sharing options...
DCdakota Posted August 12, 2013 Author Report Share Posted August 12, 2013 I have a hypnotic "1500" watt never clamped but I'm thinking I'm putting around 600 to the sub, its in a single cab (no center or passenger seat). Link to comment Share on other sites More sharing options...
TeamHT Posted August 12, 2013 Report Share Posted August 12, 2013 Tune to 33-34Hz, set your ssf at 30, and give it 12^2 of port Tell me...does this smell like chloroform to you? Link to comment Share on other sites More sharing options...
CleanSierra Posted August 12, 2013 Report Share Posted August 12, 2013 Which truck specifically, not just,"I have a regular cab". I have a 2003 full-size GMC Sierra, also with the center console taken out. And why is your passenger seat out as well? If you want a truly flat responding box, you may have to sacrifice some SPL to do that. A well ported box will HAVE a peak around tuning. So if you skimp on port area, you may get that flatness you desire, but may lack your highest SPL score. It probably wouldn't be MUCH of a sacrifice, just a slight one. As others said, your box tuning and design are what affect your ability to play certain frequencies, nit the sub's Fs. You didn't mention the internal volume of the box you're currently running, what is it? How many cubes and what size port are you currently running? Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
CleanSierra Posted August 12, 2013 Report Share Posted August 12, 2013 Pics of your current box in the truck would help also! Are you running a slot port, or and aero/round PVC port? Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
DCdakota Posted August 12, 2013 Author Report Share Posted August 12, 2013 Its a regular cab 2001 Dakota with all black interior specific enough? But the box is 30w X 19h X 18d and the slot port is 3w X 17h tuned to 41 using the 12v.com. but I just realized the back of the port (the part that goes across the rear) is only 2.25 instead of 3" could that be my problem Link to comment Share on other sites More sharing options...
CleanSierra Posted August 12, 2013 Report Share Posted August 12, 2013 I guess I could have made the assumption based on your screen name. So this is a 15" Level 4? Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
