3000 Watts for $300 - To Good to be true? BB5000D AD-1 Results
If anyone else has amps that they would like to see dyno'd, please post them. I will try to test some if I can find them to show the results. We are building a test bench currently. Waiting on the new batteries and 400A power supply to show up. Join my group on facebook "517 Audio". If I have to remove videos from youtube, they will always be there!
Build In Progress!
2000 V6 Mustang
H/U - JVC KW-ADV64BT
8 - P3D212's / 14cu. ft. / 34hz
Front - T1675x2, PPS4-8x4, T1TSx4
Rear - T1675x2, T165x2
Sub Amps - T2500-1bdCPx2
Mids/Highs Amps - T600-4x2
3SIXTY.3 Signal Processor
51Ft. RF 1/0 Spool x 2
Excessive Amperage 300amp Alternator
VMAX CT2500 x 2
Optima Yellowtop
Think I may pick one of them up for sure. U got a gut pic?
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
Mazda posted one a little while back. Credit goes to him for the video
Build In Progress!
2000 V6 Mustang
VMAX CT2500 x 2
Optima Yellowtop
They seem to be built pretty well. I'm currently running it in my 05 Impala on 3 Hertz HX 250D's @ 2ohms (I'm not an idiot, three dual 4 hertz subs sit at 2 ohms). Sound quality is still good compared to my T2500-1bdCP and output is not noticeably different.
Build In Progress!
2000 V6 Mustang
VMAX CT2500 x 2
Optima Yellowtop
I beleave with a good 14v it will do 2500-2600rms but still $300 thats not bad
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
You think so?
and to hold 14v, all day.. your willing to drop that money,.. but, not drop it in a amp that will do it all day, at lower?
Im not starting shit... im curious. Is all
SECOND EDIT- also, that is a 1ohm reactive.
Meaning, youll have to wire down lower than that. Meaning, more electrical. And, more demand on the amp.... again.... just saying....
When we get the power supply and batteries in, we will bench it with better voltage. Keep in mind, the alt was not spooling on the certified run. I'd expect to see at least 2300 out of it certified @ 14.4 volts. Name another amp that will do over 2000 watts on the AD-1 for under $300.
Build In Progress!
2000 V6 Mustang
VMAX CT2500 x 2
Optima Yellowtop
We did AD-1 it at a half ohm, it never got warm or went in to protect. I'd be confident running it safely at a half ohm with a decent charging system
Build In Progress!
2000 V6 Mustang
VMAX CT2500 x 2
Optima Yellowtop
  • Who's Online   0 Members, 0 Anonymous, 1609 Guests (See full list)
