Am I Killing My Alternator?
Ditch the cap and see if it still happens. You never know.
I'm confident in saying that won't make a difference
Second hand alt might be on it's way out as well, might have to just baby it for a while till you can get new replacement for it.
I was thinking the same, I will check what its pushing out tomorrow.
also on the alternator there is only a live wire and a plug with 2 small wires coming out of it.
You should have no alternator problems with that small an amount of power, even on the factory electrical system.
Reading battery voltage with a meter isn't the correct way to check a battery, either. You have to put a load on the battery in order to check it.
Sounds to me like your battery is shorting when the alternator is sending a charge current to it. I would have someone with a battery tester do a load test on it. And.. make sure the battery posts & terminals are clean and that ALL ground connections are clean.
Facebook: facebook.com/audioanarchyllc
Instagram: audioanarchyllc
Youtube: youtube.com/bbeljefe
  • Who's Online   0 Members, 0 Anonymous, 664 Guests (See full list)
