Helix shallow mount subs
deathcards
looking at Helix Esprit E8W shallow mount i would get 2 for a 2 ohm final load. i am using them to beef up my mid bass seeing as my box doesn't like the midbass notes very well. i had a feeling it wouldn't but had to try ;) , anyways i would use them for around 80-125 Hz just wanting some opinions on if it would sound good if the box is air tight. i may go a little bit higher on frequency but i would want to hear it first
http://www.crutchfield.com/p_975E8W/HELIX-Esprit-E8W.html?tp=111
would probably do factory recommended airspace
skar sk2500.1
alpine HU
vxi65 components on BA gt-275
2 x-15 sundowns
Are your midbass in the component sets not giving you enough output? It looks like a nice driver and I'm sure it sounds great but I could recommend a pair that would keep you under the price of one of those Helix; that will play higher, and be better suited for midbass. Do they need to be under a certain depth? These will play up to 800 hz if you want. You would want to wire them in stereo L+R if that were the case.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=264-1102
These are deeper but they are a proven performer. I could throw out a couple more but want to make sure depth is not an issue.
2005 Ford Focus zx4
AMT's and Planars
18" Infinite baffle
not sure if those will work i am very limited on space under my back seat
skar sk2500.1
alpine HU
2 x-15 sundowns
That looks realllllly similar to a kenwood excelon 8"
From personal experience: Tang band w6-1138 does pretty well in the midbass department
yes i see they have similar cones
would a 3 way setup have more midbass say something like this http://www.sonicelectronix.com/item_24363_Precision-Power-PPI-PC3.65C.html
if it does maybe i will just pick up two sets of these for front and back and a good 4 channel like helix dark blue or zapco
skar sk2500.1
alpine HU
2 x-15 sundowns
  • Who's Online   1 Member, 0 Anonymous, 2080 Guests (See full list)
