Loading up a 94 S10 reg cab, need help.
Hello
I am going to be adding 1500-2000lbs of. Equipment into this truck with 90% of it in the bed. I need to know if I am going to have issues with my suspension and what I would need to do for all the weight. Not sure if I will need heavy duty shocks or what?
Thanks
Alpine CDE-HD149BT Head Unit
Hertz HSK 165XL
Audison SR4 (Running the Hertz 6.5)
Audison SR2 (Running the Hertz Tweets)
Ascendant Audio Mayhems 4- 12" (Being Built)
DC 7.5K
230 AMP Singer ALT
6 XS-D3000 Batteries (Back) (In the works)
1-XS-D3400 Battery (Front)
Lots of SHCA Wire and Accessories.
I don't know alot about suspension but I can tell you you're going to have some issues adding that much weight. Hope you're dropping a V8 in it first. I'd say air bags might be a route for you but others will probably have much better ideas for you
you going to have weight problem differently get some king of v8 in and add helper bags with tank and compressor so you can adjust the bags or go the cheap way just add the helper bags and just put a plug so you can use an air compressor.
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
  • Who's Online   0 Members, 0 Anonymous, 1667 Guests (See full list)
