Amp going into protect, then voltage surge? AGAIN! Dif amp?
Anyone?
Dude... your power supply (like i said in around my second post) took a shit..
Im sorry. You now, (if its worth it) call RF, i have the number, you talk to Forest or Ami, and you get a rma number. You pay for a flat rate.
Sorry... I knew it wasnt looking good bro
he said it was a different amp he took the RF P8002 back and now he has a different amp in an its doing the same thing get the alt check some time when idle it will show 13.7v but when its in a bend the voltage will shoot through the roof had the happen with a customer on a car it has no stereo or anything but at idle 14v and some reason the battery will be dead the next day took the alt to oreilly auto under load it jump to 20+v
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
Yes this amp is my old P3001 that ive never had a problem with ever... Now tge chances of it happening 2 times?... I dont think its the amps... I dont drop below 13.9 ever. Even when slamming like last night when it cut out
2007 Volvo S40 2.4i (no turbo :( )(Soon XS Power D2400) Stock battery for nowRockford Fosgate 4 gaugeAudioque 6.5" Mid Bass (front)Rockford Fosgate T1 Tweets (front)Rockford Fosgate T2 6.5" Mids (rear)Rockford Fosgats T600-4 (Mids and highs)Rockford Fosgate P3001Fi SSD 12" with PSI recone, building box<p>400 watts, 139.3 @ 42 hz , in the kick window open. Build log!!http://www.stevemeadedesigns.com/board/topic/159148-2007-volvo-s40-audio-build-start-to-current-comment/
And another thing... The coils on the sub look fine but it is SMOKING HOT!!!!
No no its not!
No i didnt, each power run is straight off the back battery. And yes they're at 2 ohm... What RF recommenda
still get the alt check out something tells me their something wrong with the car electrical
2 sundown sd-2 d4
flex tech
box design by Joe X
  • Who's Online   0 Members, 0 Anonymous, 702 Guests (See full list)
