Tool maker Battery Terminals
Does anyone have experience with the toolmaker battery terminals for batteries with top posts (sae type) I made my own with 1/4" and it seems its a bitch to tighten them down. Looking at theirs they seem like it might be worse since they are way thicker.
Just wondering who has used them, and how well they tighten down on the post.
the key is hole that slides on the battery needs to have a taper to it. because the post itself is slightly tapered. i work in a machine shop and have had blocks of aluminium for months but havent done it because i dont wanna fork out the cash on a tapered reamer.
my issue with the TM ones is the first one broke... snapped at the corner where you tighten so it was very loose... he got a new set out to me very quickly but they just don't fit on tight/tight ... I can wiggle them off with a little effort... I had a thread on another forum where he had a vendor spot for a longer time... since its in the rear I left it alone... I'm looking at getting these when I redo the wiring...
http://www.wiringproducts.com/battery-and-power-distribution/battery-terminals/specialty-and-audio-battery-terminals
Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear)
beaker- I know this sounds like a lot of anime bullshit, but it is true.
I use these on both my front and back batteries, i have had them for a few years now and they hold 3 runs of 1/0 along with a wire to my fuse block under the hood with no problems at all and everything stays nice and tight.
http://www.amazon.com/Pico-Military-Terminal-Positive-Negative/dp/B001QRTZR0/ref=sr_1_1?ie=UTF8&qid=1377172046&sr=8-1&keywords=military+battery+terminal
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
I like those, and i can put a longer bolt in if i need more connections too,
  • Who's Online   0 Members, 0 Anonymous, 1560 Guests (See full list)
