Need Help With Center Console Sub Box for Truck!!!
I am looking at building a center console sub box for my 2004 Chevy Silverado 1500 LS Extended Cab. I recently picked up two Sundown Audio e8v3 D4 subs for $140 New and wanted to build a center console box in replacement for the factory front middle seat. I was thinking ported with the port at the bottom facing back towards the rear seat, or should I go sealed? I will be building the box out of 3/4" MDF and fiberglass If possible. If someone could build me a box design for the two subs that would be great because I do not know how. **What Frequency should I tune the box to, I think I know how I am going to build it (1.5 Cu. Ft. after displacement) but should I do the recommended 35hz or should I go 33hz, 32hz, or 30hz?**
Build it to 1.2-1.5 net
Single 4" or 2x 3" aeros
Tunning as low as you can get
Bear in mind you'll be lucky to get 35hz let alone 33 or lower
But if you design allows 32-33 is good if you like music that calls for it
Other wise 35-42 for a good wide range of music
My sa8v1.5 (very close to the e8) are at 33hz and I love them
Personal if you can, put them under the rear seats if you have them fitted.
A 1.5net box for 2 e8 will be close to 2.5gross
That is no small box I can tell you
Take some measurement of what you to work with before you do anything
Post them up here and see what will fit
  • Who's Online   1 Member, 0 Anonymous, 610 Guests (See full list)
