jarrius Posted August 22, 2013 Report Share Posted August 22, 2013 IMO i would not buy this thing $300.00 pissed away and you will not be happy with it save up and buy something much better that will last. 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole Link to comment Share on other sites More sharing options...
Guest Posted August 22, 2013 Report Share Posted August 22, 2013 lol it looks like the same exact amp, just a different casing and model number. 5 bucks says its 2 ap 1500's inside still. Link to comment Share on other sites More sharing options...
Hammer Knock Posted August 22, 2013 Author Report Share Posted August 22, 2013 yes its the same. they updated the ap30001d. then put the new look to it after they single terminable it if the car doesn't stall, you have enough voltage. DEH-6400BT BC3500D on 2 x 12" Lanzar Opti1233d QBOMB 4.5cu 1/0 awg, Lanzar AMPKIT0 Singer 275 + LCAKT50DBL Link to comment Share on other sites More sharing options...
Hammer Knock Posted August 28, 2013 Author Report Share Posted August 28, 2013 IMO i would not buy this thing $300.00 pissed away and you will not be happy with it save up and buy something much better that will last. pissed away on under rated amp????!!!! if the car doesn't stall, you have enough voltage. DEH-6400BT BC3500D on 2 x 12" Lanzar Opti1233d QBOMB 4.5cu 1/0 awg, Lanzar AMPKIT0 Singer 275 + LCAKT50DBL Link to comment Share on other sites More sharing options...
n8ball2013 Posted August 28, 2013 Report Share Posted August 28, 2013 Lol its not under rated its a piece of shit THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
CleanSierra Posted August 28, 2013 Report Share Posted August 28, 2013 Lol its not under rated its a piece of shitThe thing doesn't abide by the laws of electricity or physics N8. It has Super FETS and a power supply that, when exposed to ultraviolet or infrared light, it can pull a negative ohm load... Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
deathcards Posted August 28, 2013 Report Share Posted August 28, 2013 Lol its not under rated its a piece of shitThe thing doesn't abide by the laws of electricity or physics N8. It has Super FETS and a power supply that, when exposed to ultraviolet or infrared light, it can pull a negative ohm load... i knew it and the audio pipebomb only explodes when the ozone has a small hole so when the uv rays hit it will blow metal shavings and burning metal everywhere skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps Link to comment Share on other sites More sharing options...
jarrius Posted August 28, 2013 Report Share Posted August 28, 2013 IMO i would not buy this thing $300.00 pissed away and you will not be happy with it save up and buy something much better that will last.pissed away on under rated amp????!!!!Yes pissed away. Explain to me how it will do 3k at 2ohms AND do 3k x2 at 1ohm. Also tell me of another company that sells a 3k amp at $300 that WILL do rated power... None. So that's $300 you spent on a amp that may do 1500wrms to 2k ( giving it the at most higest it will do clipping to hell and distorting like shit) when you can save up a bit more and get a good amp that will do its rated power at all ohms ad sound so much better. So once again. I would not PISS away 300 for that amp that will not do rated power 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole Link to comment Share on other sites More sharing options...
Hammer Knock Posted August 29, 2013 Author Report Share Posted August 29, 2013 IMO i would not buy this thing $300.00 pissed away and you will not be happy with it save up and buy something much better that will last.pissed away on under rated amp????!!!! Yes pissed away. Explain to me how it will do 3k at 2ohms AND do 3k x2 at 1ohm. Also tell me of another company that sells a 3k amp at $300 that WILL do rated power... None. So that's $300 you spent on a amp that may do 1500wrms to 2k ( giving it the at most higest it will do clipping to hell and distorting like shit) when you can save up a bit more and get a good amp that will do its rated power at all ohms ad sound so much better. So once again. I would not PISS away 300 for that amp that will not do rated power 1.5k x2 at 1ohm. not 3k. also its around 350 and that's not even retail. i do not know from ear how many watts im pushing to (2 opti1233d) but sounds 600+watt easy, but i could be wrong because i do not know by ear. also yes its tuned with dd-1, maybe something to put on the AD-1 to see how bad off this amp really is? if the car doesn't stall, you have enough voltage. DEH-6400BT BC3500D on 2 x 12" Lanzar Opti1233d QBOMB 4.5cu 1/0 awg, Lanzar AMPKIT0 Singer 275 + LCAKT50DBL Link to comment Share on other sites More sharing options...
Hammer Knock Posted August 29, 2013 Author Report Share Posted August 29, 2013 Lol its not under rated its a piece of shitThe thing doesn't abide by the laws of electricity or physics N8. It has Super FETS and a power supply that, when exposed to ultraviolet or infrared light, it can pull a negative ohm load... i knew it and the audio pipebomb only explodes when the ozone has a small hole so when the uv rays hit it will blow metal shavings and burning metal everywhere what the??!!!! if the car doesn't stall, you have enough voltage. DEH-6400BT BC3500D on 2 x 12" Lanzar Opti1233d QBOMB 4.5cu 1/0 awg, Lanzar AMPKIT0 Singer 275 + LCAKT50DBL Link to comment Share on other sites More sharing options...
