Hey guys, I finally got around to installing sound dampening in my car
Went with GTMat, because they are a local business and all
Anyways, got a few questions, hopefully you guys can give me some insight
1. I've eliminated most, if not all rattling and whatnot at lower frequencies, however at 40hz+ I'm still getting a lot of vibration and noise from the trunk, is there anyway to solve this? Do I just add more stuff?
2. I don't know if I'm completely crazy, but it seriously sounds like my system isn't as loud anymore, is this just because there isn't a horrendous amount of noise from the trunk, or did I break something?
Any input is appreciated
2005 VW Jetta TDIStock headunit(2) Sundown Audio E-15s @ 35hzPower Acoustik BAMF 1250.2 (will be replaced with Cadence mono)GTMat 50mil Sound Dampener
http://natsurutech.blogspot.com/
Well poop
My other option I was considering was to make a horn loaded enclosure with ports firing forward
This should give me the same affect that the location in the trunk gives me, while reducing total rattling
but with my luck it will burst into flames or something
Did u use gt mats butyl? Cuz the stuff is asphalt based otherwhise..
My setup,
Digital Designs M80
3 Re audio 10's ported tuned to 36 hz
Kenwood x-696
SHCA 0 gauge
Polk audio coax running off hu
get some weather foam stripping and put it around the trunk.. for $4 it helped a lot in my case..
sometimes Loud is NOT pretty
Sounds like its safe to go ahead and bend that ass over.
  • 1 month later...
Im about to order some of the 110 stuff. Did you have any adhesion problems?
https://photos.google.com/photo/AF1QipP7rjav9cD9UFdAYBJmz4M4LoNlF26ng1xhAf4Uhttps://photos.google.com/photo/AF1QipP7rjav9cD9UFdAYBJmz4M4LoNlF26ng1xhAf4U
2013 DODGE CHALLENGER R/T
SUNDOWN ZV4-18
CRESCENDO 3.5K
PIONEER AVIC 5300 NEX
ALPINE TYPE R 6.5S & 6X9'S
ROCKFORD FOSGATE 1.5" TWEETS
5 C&D TECH BATTS
something you can try is to move the latch your trunk hooks on to, so it holds your trunk tighter to your car. and I have a car with the subs in the trunk and ive noticed that the metal bars that go across the bottom of the back dash to hold the trunk open shake like crazy. I put some of this http://www.homedepot.com/p/Armacell-Tubolit-3-4-in-x-6-ft-Polyethylene-Pipe-Wrap-Insulation-OEP07838/100539941#.UlQh_SbD81I on it and it don't rattle at all.
AQ - SQ For Life
i would NOT order their 110 it is asphalt based and for deadining thats not good i would safe up and get some second skin or other real butly deadener but my gt mat (i regret usimg) i will admit it sticks great just orep the surface 100 degree summers and -10 winters it hasnt moved
My setup,
Digital Designs M80
Kenwood x-696
SHCA 0 gauge
I used some real cheap sound deadener. its called peel and seal from Lowes, its like $16 for a roll that's 6" by 25'. its not the absolute best but for its price cant beat it.
AQ - SQ For Life
  • Who's Online   0 Members, 0 Anonymous, 1958 Guests (See full list)
