soundstream15 Posted August 27, 2013 Report Posted August 27, 2013 so i insalled my mechman 170amp alternator, im running a crunch GP3000d. big 3 upgrade, all 1/0awg, optima yellow top under the hood and a kitneik hc2400 in the back, i was bumping tonight just played a song and my voltage dropped to 11.9 for a sec well with my stock alt it would drop to 11.6 i mean, idk if this amp is just so damn power hungry i need 10 batteries or my optima is taking a shit lol
SnowDrifter Posted August 27, 2013 Report Posted August 27, 2013 Have you clamped your alt to be sure it's putting out? Check for belt slip? Where are you measuring voltage ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
soundstream15 Posted August 27, 2013 Author Report Posted August 27, 2013 I have a volt meter, there is no belt slip either
SnowDrifter Posted August 27, 2013 Report Posted August 27, 2013 What/where is your volt meter hooked up to?How do you know you don't have slip? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Swordlordboy1234 Posted August 27, 2013 Report Posted August 27, 2013 Proper belt tension is important. I doubt its the alternator not putting out current but a PROPER belt tension is extremely important. Can't stress that enough, Beyond that I'd just clamp your draw? And clamp your alternator? Refer back to snow for better advise My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
Swordlordboy1234 Posted August 27, 2013 Report Posted August 27, 2013 Proper belt tension is important. I doubt its the alternator not putting out current but a PROPER belt tension is extremely important. Can't stress that enough, Beyond that I'd just clamp your draw? And clamp your alternator? Refer back to snow for better advise Edit. As a mechanics son, I've be lectured up and down about proper belt tension. I have some belt squeal when under load, but I know I have the perfect tension. Over tight ruins your herrings and pulleys and hurts output. Under tighten will lose output and hurt belt, maybe causing the whole belt to slip off which is REALLY bad, I may have hated dad at points, but I've come to realize all the mechanic stuff he taught me is a good thing. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
soundstream15 Posted August 27, 2013 Author Report Posted August 27, 2013 My amp. I don't know how to check for belt slip, don't hear anything or what not. I never knew this about alternators, thanks for that post Jeff. I'll buy a new belt
soundstream15 Posted August 27, 2013 Author Report Posted August 27, 2013 My belt looks new tho, it has the grooves in it, along with the writing on it, you think it's a few months old, that's why I assume it is not my belt..
SnowDrifter Posted August 27, 2013 Report Posted August 27, 2013 Look on your alt. Any sort of black, powdery residue on it? And measure your voltage drop at the amp with a DMM ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
soundstream15 Posted August 27, 2013 Author Report Posted August 27, 2013 I'm at work so I'll have to go out and look when I can, on the belt or on the alt? If you want you can PM me or call me lol
