shadowcaster Posted August 29, 2013 Report Posted August 29, 2013 Hello again guys,Decided to sell the 2 Sundown E 12's i had and get a single E15 and RF prime series amp 500x1d for it.Heres the box design 2 questions:Are those specs right? also about orientation of sub/port right,left,high,low ETC. and main info--99 civic ex--daily--rap mainly a little rock/metal 2000 blazer LS 240 mechman 2 b2 HN v3 15s crescendo bc5500 @.5 1/0 ebflex ofc d680/g31 kenwood deck mb quart components crescendo pwx 8s lots more to come blazer build http://www.stevemeadedesigns.com/board/topic/204432-shadowcasters-2k-blazer/ 142.8db MECA 2016 PA state champ mod 1 class
knockin'hoe97 Posted August 29, 2013 Report Posted August 29, 2013 If i'm not mistaken the general rule of thumb for "port area per foot" for aeroports is 9-12. I'm no expert so just take my opinion with a grain of salt but i think 3.54 is a good bit too low.
shadowcaster Posted August 29, 2013 Author Report Posted August 29, 2013 thanks i thought it was 9-13 for port area alone. 2000 blazer LS 240 mechman 2 b2 HN v3 15s crescendo bc5500 @.5 1/0 ebflex ofc d680/g31 kenwood deck mb quart components crescendo pwx 8s lots more to come blazer build http://www.stevemeadedesigns.com/board/topic/204432-shadowcasters-2k-blazer/ 142.8db MECA 2016 PA state champ mod 1 class
shadowcaster Posted August 29, 2013 Author Report Posted August 29, 2013 ive moved some numbers around and am having issues getting a low tune when i try for 9+ on port area per foot. max specs for the trunk are 35 wide 17 tall and 24 deep 2000 blazer LS 240 mechman 2 b2 HN v3 15s crescendo bc5500 @.5 1/0 ebflex ofc d680/g31 kenwood deck mb quart components crescendo pwx 8s lots more to come blazer build http://www.stevemeadedesigns.com/board/topic/204432-shadowcasters-2k-blazer/ 142.8db MECA 2016 PA state champ mod 1 class
Sergeant_Skyrim Posted August 29, 2013 Report Posted August 29, 2013 You're most likely going to have to do a longer port. Longer port will lower tuning, bigger port area will increase it. Just need to find a combination of the two that will work without choking the sub and also give you the tuning you'd like. You'll likely need to bend the port if you want it firing same way as sub or you can have it come out of the side so that you have the 34 inch width of the box to work with Build in progress
shadowcaster Posted August 29, 2013 Author Report Posted August 29, 2013 ill play around abit at work see what i can do.id like to build or atleast start it this weekend having the holiday off is nice lol 2000 blazer LS 240 mechman 2 b2 HN v3 15s crescendo bc5500 @.5 1/0 ebflex ofc d680/g31 kenwood deck mb quart components crescendo pwx 8s lots more to come blazer build http://www.stevemeadedesigns.com/board/topic/204432-shadowcasters-2k-blazer/ 142.8db MECA 2016 PA state champ mod 1 class
john253a Posted August 30, 2013 Report Posted August 30, 2013 Aim for 4net with a either 8" aero 2x 6" 3-4x 4" My question is why go from 2x e12 to a single e15 You dropping cone area and power and staying the same on coil and Xmas for 1 sub If going from 2 - 1 idd do and sa15
shadowcaster Posted August 30, 2013 Author Report Posted August 30, 2013 Ive had 2 12's for quite a few years now and wanted a change,i hope early next year to upgrade the sub and amp but that's not certain yet.thanks for the tip on the aeros,im still workn with the numbers im getting closer tho lol 2000 blazer LS 240 mechman 2 b2 HN v3 15s crescendo bc5500 @.5 1/0 ebflex ofc d680/g31 kenwood deck mb quart components crescendo pwx 8s lots more to come blazer build http://www.stevemeadedesigns.com/board/topic/204432-shadowcasters-2k-blazer/ 142.8db MECA 2016 PA state champ mod 1 class
shadowcaster Posted August 31, 2013 Author Report Posted August 31, 2013 so im at 12.8 as port area per foot and 3.9 net if this is right i have a few more questions 2000 blazer LS 240 mechman 2 b2 HN v3 15s crescendo bc5500 @.5 1/0 ebflex ofc d680/g31 kenwood deck mb quart components crescendo pwx 8s lots more to come blazer build http://www.stevemeadedesigns.com/board/topic/204432-shadowcasters-2k-blazer/ 142.8db MECA 2016 PA state champ mod 1 class
