XS Power
If it's an intellicharger, the float mode it goes into is designed for long-term use. I've left mine on for 6 weeks while I've been out of town
COOL !
so even when the light is green, its tending ?? So to speak? i did NOT know that... ( i thought ONLY amber ment charge)
Green light = done charging, charger is in float mode at ~13.3-13.5v iirc. Pull out a DMM and check ;)
I leave a fluke on it at all times..
What i have seen, is, when it dips,.. i need TO RESET the charger,.. to go amber....
EDIT- does that make sense Chris?
It wont sit and charge when needed, 4 weeks out.
It will charge, up to a point.. then.. go green.. ive NEVER seen it go amber, fill, go green, ... wait, then GO AMBER again, on its own..
never....
Edited by KyLar96
You shouldn't have to do that. It's normal to stay green. No need to switch back and forth.
It charges the batteries, the flips into float mode to it keeps them topped off. All on it's own. Set it and forget it.
What sort of voltage are you measuring?
Edited by SnowDrifter
lol it wont go back to amber. if its amber that means its in serious charge mode. green means its in float charge, also called maintenance mode. it wont ever need to go back to amber because the battery is still fully charged.
Ive had it on green,.. then. turn it off.. and turn it back on.. and will go amber.. :shrug:
Ill do a vid tomorrow...
Yeah if you turn it off then back on it will reset and do the charge cycle again.
My question is: Why are you manually cycling it? There's not need to
Well,
I have it plugged in at all times.
I get home from work.. its on green.
I turn it off... go inside, grab a beer, and come out, and turn it back on, and it goes from a float charge (green) to a amber charge 13.3 ish...
Ive done that for months...??
  • Who's Online   1 Member, 0 Anonymous, 1878 Guests (See full list)
