gattiboy13 Posted September 1, 2013 Report Posted September 1, 2013 So I plan on getting this sub http://www.woofersetc.com/p-11689-x-10-d2-sundown-audio-10-dual-2-ohm-1250w-rms-subwoofer.aspx and this is my amp I already purchased http://www.woofersetc.com/p-11280-gm-d9601-pioneer-monoblock-2400w-max-class-d-gm-series-car-amplifier.aspx will my amp be enough or should I go with a lower model sub? I will not swap out amp since I am very happy with it.
SnowDrifter Posted September 1, 2013 Report Posted September 1, 2013 That amp has a (3), 40 amp fuses. Realistically it should put out somewhere in the 1200 watt neighborhood. So I'd say that's fine to get an X-10. You could step down to an SA-10, but depending on your experience level you may or may not blow it. It's give/take. An sa-10 would be cheaper, but you'd need to be more careful with it ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
gattiboy13 Posted September 1, 2013 Author Report Posted September 1, 2013 Ya I have the Fosgate T1 now and it cannot handle my amp, so I think I will go with the X series. Thanks.
SnowDrifter Posted September 1, 2013 Report Posted September 1, 2013 It should be able to. It's a 3" coiled sub. Let me ask this: How did you set you gain? I don't care what it's set to. I want to know the reasoning/processes behind that set point ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
gattiboy13 Posted September 1, 2013 Author Report Posted September 1, 2013 I used an SMD meter to set gain and frequency cut off too. And yes all was done correct as well as deck clipping. And sub was in a custom specs enclosure designed by fosgate themselves.
SnowDrifter Posted September 1, 2013 Report Posted September 1, 2013 What track did you use to set the gain on your head unit? Then the amp? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
SLAYER1805 Posted September 1, 2013 Report Posted September 1, 2013 Your T1 can't handle that amp? Something doesn't seem right there lol
gattiboy13 Posted September 1, 2013 Author Report Posted September 1, 2013 I assure all was done as directed properly. Yes that sub sucks ass, sorry to burst your bubble but it is true...it cant handle that amp. That pioneer amp is a beast! much more powerful than u may think. Well thanks a lot guys, I appreciate all the advice, found a buyer for my T1 so will be getting the X series asap! Thank you guys again on the advice.
SnowDrifter Posted September 1, 2013 Report Posted September 1, 2013 What track did you use to set your deck and amp? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
SLAYER1805 Posted September 1, 2013 Report Posted September 1, 2013 That sub doesn't suck ass, its comparable to other 3" coil subs essentially, its just overpriced. I know people who have run them on more than RMS with no problem at all, new and old models
