2 12 isobaric 6th order.
cabl :D the thing is compartment size... to I go with the 2 cubes sealed for the rear and then just find a good tuned size port combo for the front how do I match the two I guess is my biggest question. I didn't do the math for the builds I helped with it was all construction.
I'm not an enclosure designer ... just don't have time, but I have studied what different enclosures should do and not do in the field with different applications ...
cool hmmm I'll have to look up something on line for it. :D the help is appreciated guys thanks for the knowledge :D
<img src=http://i1332.photobucket.com/albums/w610/beastly666bassboy/IMG_9611192581855_zps9b9b76be.jpg border=0 alt= height="75" width="800">
Growing old is necessary... growing up is an option! Have fun or you might as well fall into a 6 foot deep hole. Its much easier to be smart and act stupid then it is to be stupid and act smart! You're only limited by your imagination! Stop limiting yourself! Optima yellow top6 guage cableJVC KD S36 headunitPower acoustik 1600w 750w rms @2 ohmsTwo MTX thunder 7000 10"sSealed box @4.04 ft^3Mojo Mat in the trunk Coming soon:1/0 awg cablebig 3... in 6 gauge(till i can get the money for 0)planet audio Crossover.2- 3.5's for the front.2- 6.5's for the doors2- 6x9's for the rear3- MB Quartz amps to power it all.1- 6" aeroport...soon! <p>My Log!
Am not sure if this is any good but thought it looked simple and legit, although I could be wrong dude, lol
http://www.ajdesigner.com/speaker/
25d9cf71-fff8-4b67-a8f5-28c80d5ea859_zps7d3fe7f6-90c4-4939-b709-43f0e5812212_zps
2018 Honda Civic Sport Hatchback (build in progress)
NVX Sound Deadener (Front Doors)
Stinger FAST Rings
Stock Electrical
SSA Evil 6.5's Front Speakers
Stock rear speakers
MB Quart ONX4.80 speaker amp
Rockford Fosgate T-1500bdcp
DC Level 4 12" D1 @ 2-ohm
Box In Design Stage
Stock Radio
My Build Log
I would avoid a 6th order if I were you. Pain in the ass and you'll never get it right. Stick to your sealed and vented boxes for now. When you have your technique nailed, maybe branch out and try some new things. Do you know the Qes and Fs for the subwoofer? What is the model number of the sub in question?
The 6th will have a narrow pass band as well, so SPL oriented with a bunch of output in tuning range, quick falloff above and below tuning. This is not to say you can't have a musical 6th order, but testing and tweaking is absolutely necessary to get them right, and like I said, pain in the ass.
well yesrerday I got the reply from mtx. with the specs for these drivers. it shows an fs of 33 with is a little higher than I expected so I'm going to get on winisd and get to making my box... still shooting for a 6th. because I'm kind of in a go big or go home sort of mood with this on :D so yeah... it'll be in the works. :D next paycheck I plan on getting my wood together. :D
To establish your pass band and get some decent useable frequency, a LARGE vented rear chamber tuned low will help you to avoid from unloading. Like BIG, 6-7 cubes(for non isobaric loading). Since you plan on isobaric and running 2 subs compound loaded, volumes can be HALF of what one driver wants even. The rear vented chamber needs to be tuned low and the front chamber will need to be tuned at your higher frequency to establish your pass band. From what I've read, you can find that rear chamber in the 20s and front chamber in the 40s. So just straight guessing, since you're using 2 subs performing as one, and you have the ability to have a much smaller than typical enclosure I. would shoot for the large rear chamber to be in the 3-3.5 range and tuned somewhere between 22-28, front chamber tuned 40-50 Hz and be about .75-1 cubes.
And that is me not really knowing anything about the sub specifically. What is the Qes? They sent you this spec I assume?
hmmm so I'm guessing that the frequency that's passed will be between the two tuning frequencies?
Like I said, I didn't model ANYTHING, those are pure guesses from how I think they would model somewhat well. You will need one HELL of a mid stage. And you still run the risk of blowing a sub pretty easily and once you know something is wrong, it's too late.
Qes is .23. yeah I'm just researching so any little knowledge I can get is useful :D been piddling with win isd a lil bit too. so we shall see... but you say rear lower front higher... hmm k I'll keep that in mind. :D
  • Who's Online   0 Members, 0 Anonymous, 593 Guests (See full list)
